Question about Radio Communications
Programing this is not a problem its more of a question can a gtx be program to work with conventional programming
  • 14 Answers
I assumed that you mean Motorola GTX handheld radio. It can be programming to work with conventional, if it's a trunking radio then need to keep at least one trunking in radio, otherwise it lost all trunking.
Posted on May 13, 2009
Cant program motorola gtx 800
Hi Zach,
To get you going in the right direction try the following: join yahoo group specific to your radio Make/Model, there are experts to give you all the info you need, plus you can download manuals, schematics and other goodies.
You will need programming software, and I'm sure they can help.
Feb 02, 2013 | Motorola Gtx 800mhz Ltr Portable Radio...
Cant program gtx 800
Do you have the programming software? What specific problem are you having?
Dec 14, 2012 | Motorola Gtx Privacy Plus 800mhz Portable...
Broken squelch button on the bc898t
Because the sqelch control is broken, you may have to send your scanner to Uniden for repair
Oct 05, 2012 | Uniden BC898T Base Scanner
I connected the cable and managed to transfer one picture from my Nikon S8100 to the computer. The computer tells me that there are no more pictures to transfer, but I cannot find them!!! Where should I...
When you connect your Nikon camera to your computer some program is automatically loading up and then transferring your pictures over. If you haven't deleted the picture from your camera then reconnect your camera back to your computer. Follow the same steps you did the first time but watch the screen carefully. When the program tells you it is copying the picture over it should have a window open to the directory that it is using for the transfer. You should be able to get to that directory in your computer to work with your picture.
If the program deleted the picture from your camera then just shoot another picture so that you have something to work with. Most programs use some kind of a naming convention when it is saving your pictures, Usually it is a name made up of the date you are transferring the picture on as well as a number. The program should open a window before the transfer is completed to allow you to use your own naming convention.
Jun 27, 2011 | Nikon S8100 Digital Camera
Need hep programming a new uniden bcd396xt scanner
Unfortunately, you didn't specify if you needed assistance with programming digital or conventional radio systems.. but here is the info for conventional systems. Since a conventional system is really a collection of frequencies, the first thing you need to know is the frequency for each channel you want to program.
  1. Go to the Program System menu and choose New System .
  2. The scanner will prompt you for the System Type. Select Conventional .
  3. When the scanner prompts you confirm, tap YES .
  4. The scanner creates the system with a default name. Select Edit Name if you want to change it.
  5. If you need to change any of the system properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Create at least 1 channel group Each conventional system can contain up to 20 channel groups, and all systems must contain at least 1 channel group.
  1. On the Program System menu, select the system you just created.
  2. Go to the Edit Group menu and select New Group .
  3. If you need to change any of the channel group properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Create at least 1 channel in each group Each conventional system can contain up to 1000 channels in each group, and all groups must contain at least 1 channel.
  1. On the Edit Group menu, select the channel group you just created.
  2. Go to the Edit Channel menu and select New Channel .
  3. Input the frequency for this channel in MHz.
  4. If you need to change any of the channel properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Mar 04, 2011 | Uniden BCD396T Handheld Scanner
No clue how to program the scanner !!
Your best choice for software is the BuTel program. You can find it on,, or Once you have it installed you can download and program both conventional and trunked systems directly from I have the BCD996XT with Butel and RadioReference, and the combination works great.
Bill B
Apr 20, 2010 | Uniden BCD996T Base Scanner
How do I program conventional frequencies into my Uniden BC898T? I have Motorola TypeII Digital Tunking frequencies programed into Bank A and EDAC Digital Trunking frequencies programed into Bank B
Just go to Bank C or anything after that and start entering -- one channel, one frequency. It's kind of cumbersome to do by pushing the keys, but it works. An alternative is to use the BuTel software. It will simplify programming and give you Virtual Control of the scanner through your computer.
If this helps, please give us a rating. A "very helpful" would be greatly appreciated.
Nov 22, 2009 | Uniden BC898T Base Scanner
How to my motorola gtx
Yes this radios is programmable, may be this radio works on 800Mhz with trunking protocol. you´ll need a RSS (Radio Service Software) to program it and a hardware as well.
Dec 01, 2007 | Radio Communications
Can the conventional Maxxum/Dynax flash units be used with this camera?
Yes. The following Minolta dedicated external flash units are compatible with the DiMAGE A1 for automatic flash control: Program Flash 3600HS(D), Program Flash 5600HS(D), *Program Flash 2500(D), Macro Twin Flash 2400*, Macro Ring Flash 1200*. * Program Flash 2500(D) will be available around August, 2003. *Macro Flash Controller is necessary
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Radio Communications Logo
119 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
