Question about Kenwood KVT-512 Car DVD Player
Kenwood KVT-512 with bluetooth setup troubles
I have an iPhone and when I turn on the bluetooth function then do the same on the deck it comes up blank. One instruction manual says to check the other on how to set it up so i'm left confused? I had it professionally installed and they never asked to see my phone or anything so I'm not sure if they missed a step or if it's something I can resolve on my own. Thanks
  • daymon74 Mar 20, 2009
    Yep, me too. I'm connected, but no sound for my phone via bluetooth, and my ipod via ipod connector.
  • 4 Answers
With my BMW I had to connect both the solid blue (pwr ant) wire and the blue with white stripe (p conn) to the solid blue wire from the factory harness.
It isn't obvious that either of these are needed as the KVT-512 has it's own power supply but the way most factory power amps are installed the power from the KVT-512 is not used and the car manufacturers power amp needs to be turned on.
If you are listening to the radio the pwr ant wire will turn on the power amp, this didn't seem obvious because the BMW doesn't have a power antenna. And when you are using the DVD player or the iPod connection you need the P Conn wire to turn on the car power amp as the ant pwr is disabled because you are no longer using the radio and Kenwood assumes you will not need the antenna so no power to this lead.
Solder all three wires together and you should have sound all the time.
Posted on Jul 16, 2009
I need the site for kenwood kvt-512 update
try this I use this for getting user manual or leave them a question Good Luck!!!!
Techman
http://www.kenwood.ca/Support
May 14, 2010 | Kenwood KVT-512 Car DVD Player
My 5th generation ipod is reading on my kenwood kvt-512 but no music is playingits been updated to firmware version 2.5
This happened to me. What worked was turning off the ipod (not stand by mode). Turn it back on and plug it in, it should work.
Jan 26, 2010 | Kenwood KVT-512 Car DVD Player
Kenwood KVT-512 iphone compatibility
Just ignore the airplane mode prompt and if your wiring is correct everything should work.
Jul 01, 2009 | Kenwood KVT-512 Car DVD Player
Does anyone knows where to conect the dimmer wire of a kenwood kvt-514 or kvt-512??
Connect to the side light live. So when you turn the lights on it dims the display.
Jun 15, 2009 | Kenwood KVT-512 Car DVD Player
Kenwood kvt512 code
forgot my code how can i reset it
Jan 27, 2009 | Kenwood KVT-512 Car DVD Player
KVT-512 reverts to "CALL" screen.
In your wiring harness there is a brown wire posbily. I ran into a similar problem on a newer Chrysler vehicle. Make sure that brown in NOT hooked up and you should be ok.
Jan 22, 2009 | Kenwood KVT-512 Car DVD Player
How do i set up my bluetooth for my kenwood kvt-512. im trying to find the bluetooth app in the settings
The Kenwood 512 works with the Kenwood KCE-BT200 module. You need to have this box plugged into the main unit to work. If not, then Bluetooth will not be available. When you do have it connected, use your cellular phone to initiate the connection. when prompted on your phone for a passcode, it will be 0000. After successfully pairing your phone to the unit, you can access the telephone menu by holding the "FNC" key on the front of the Kenwood or pressing "TEL" from the source screen.
Aug 11, 2008 | Kenwood Car Audio & Video
Kenwood KVT-512 Car DVD Player Logo
1,822 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
