Question about DeVilbiss Pulmo Aide Compressor Nebulizer
Tubing getting hot on nebulizer
We just got this nebulizer for our son and the tubing is getting hot at the base, otherwise it seems it's working well but i know it wasn't doing this the first few times we used it. is this normal or something i should be concerned about? thanks
2 Suggested Answers
SOURCE: am i hooking this nebulizer up right
First when you turn on the neb is it running and putting out air
second is the circuit or medicine cup you have new?
if not replace if yes connect tubing to spout on neb, connect other end to bottom of cup open up and put medication inside ( you can do a trial run with water just to make sure its puffing before you waste meds.
put on mputhpiece turn on should puff out like steam if not you compressor may not be putting out enough air if over 5 years old insurance should help purchace a new one with a dr rx if not call company you got it from they usually have a 5 year warranty on them.
Hope this helps
Posted on Feb 10, 2009
Where do you load the inhalation solution?
You may have already figured this out by this time, but figured that others could have the same question. Here's a simplified explanation on how to assemble and use the nebulizer. I apologize if the explanation sounds patronizing. I'm not sure of what you may or may not understand about the nebulizer, so I'm explaining as though you don't understand it. I'd rather someone explain something in a patronizing way, than assume I have knowledge that I actually don't. At least with the former, it's easier for me to ensure my questions are answered. I also apologize for my ADHD. It often cause me to write much more than is necessary or overexplain things.
There should be two pieces that screw together to make the reservoir.
Piece #1 is the male side/bottom side and may or may not have a green cone inside. If not, there are still a plastic piece inside that forms a cone shape. This side should also have a small plastic cylinder shape on the bottom. This is where one side of the supply tube should be attached.
Piece #2 is the female side and has a larger cylinder shape on the top. When the piece is turned on its side, it sort of resembles a flashlight. This is what the breathing apparatus is attached to. You attach the tee adapter to the tube side of it. Then you attach the mouthpiece to whichever of the tee sides it fits best. Once this is all assembled, attach the other end of the supply tube to the nebulizer.
Now, back to your question. Open the reservoir, pour the solution into Piece #1, then screw Piece #2 back on. It should only take a second or two for the steam to begin flowing through the breathing apparatus once you turn the nebulizer on. Also make sure the the supply tube is attached securely to both the nebulizer and the reservoir so it doesn't pop off. Now you're ready to begin.
If you start coughing during treatment, that's fine. Don't remove it from your mouth or stop treatment. My mom was my son's pediatric nurse and trained us on its use. She said that if you start coughing during treatment, that actually helps you to inhale even more of the solution which is beneficial..
Aug 02, 2013 | Salter Labs 8900 Series Small Volume Jet...
Nebulizer wing tip tubing is stuck
Searched Google today for this same problem - Vios nebulizer tubing is stuck to the compressor at the blue rubber wing end. I tried everything, including pliers, but today stuck a letter opener in and pried it off. Adding my comment for other people searching who land on this page!
Jul 23, 2012 | Pari Health & Beauty
I'm in need of a proneb compressor nebulizer tubing adapter
As a Registered Respiratory therapist I know that alot of equipment issues with nebulizer are creative plumbing type things. I found your needed part available thru "American Allergy Supply 1-800-221-6483." Are you sure with a bit of wiggle that a simple oxygen tubing connector wouldn't work? Just asking. luisayala.jpg
Sep 23, 2011 | Health & Beauty
I have a Devilbliss Pulmo-Mate model 3650D and I plug it in and medicine does not blow out tube it only bubbles inside cup. What is wrong.
Your tubing is clogged or torn somewhere. Get a new nebulizer kit and cup and it'll be working in no time.
Jan 27, 2011 | DeVilbiss Health & Beauty
I have an Inspiration nebulizer but have no idea how to use it and no manual with it. I need to use it for my 3 year old son. Help please!!
There is not much available on this model but I found something for you here for sure so you can hopefully at least get it working for your son. I know the feeling, I had to use one of these as well when I was younger. This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. Here is the manual / guide please give it a few minutes the file is quite large:
http://www.apria.com/manuals/Respironics%20-%201020217%20Elite%20Neb.pdf
Oct 12, 2010 | Respironics Inspiration Elite Compressor...
Respironics Side Stream Nebulizer tubing with condensation
try this...
let the compressor run with only the tubing attached for a few minutes. The warm air
from the compressor will dry the moisture or condensation in the tubing. Use a damp
cloth to wipe the exterior of the tubing.
hope this helps..good luck...
May 02, 2009 | Respironics HS860 Sidestream Reusable...
Sterlize my nebulizer
From Pari.com:
What is the best way to clean and disinfect my PARI Nebulizer?
Cleaning: After every treatment, thoroughly rinse the nebulizer to remove medication. Hand-wash with warm water and dish soap. Rinse thoroughly. OR... Wash in the dishwasher using a dishwasher basket on the top rack.
Disinfecting: (done after cleaning) every 2nd treatment day, mix a solution of 1 part distilled white vinegar and 3 parts warm tap water in a clean bowl. Soak the nebulizer parts (except the tubing and mask) for 60 minutes. Rinse thoroughly. OR... Mix a solution using Control III® Nebulizer Disinfectant and soak for 10 minutes. Rinse thoroughly. OR... Boil the nebulizer parts for 10 minutes.
Source: http://www.pari.com/pdd/pdd-faqs.htm
Apr 20, 2009 | Pari Proneb Ultra II Compressor Nebulizer...
Nebulizer portion is accumulating what appears to be saliva
well i have a inhaller tube to and yes it can be straight and it can slope down too. saliva no it's not possible but it could run down your cheek. or you could go and ask where ever you got the nebulizer from
Dec 01, 2008 | RTO Spider Nebulizer
Nebulizers question
Nebulizers deliver aerosolized liquid medicine by a facemask or mouthpiece. Successful nebulizer therapy does not depend on significant patient cooperation or coordination. This is useful in the treatment of pediatric asthma, and the NIH recognizes the nebulizer as an effective delivery device for young children.
Aug 27, 2008 | Cardinal Airlife Brand Misty Max 10...
DeVilbiss Pulmo Aide Compressor Nebulizer Logo
410 people viewed this question
Top DeVilbiss Health & Beauty Experts
syspro
Tom Chichester
Are you a DeVilbiss Health and Beauty Expert? Answer questions, earn points and help others
