No charge on laptop
Laptop battery will not charge, put a charged battery in and the cord light comes on but says plugged in not charging
  • tatanka1 Mar 12, 2009
    I am told that the internal connectors might be lose and it requires a "minute" repair. Do you know the typical cost of this repair or if I can do it myself pending if I can find the part? Thank you!
  • 2,229 Answers
I agree. Batteries have a limited life. Also--once you have a new battery installed, be sure you let it discharge all the way (until the computer tells you it has to be charged--about 3% remaining) at least once a month. This will ensure you get the maximum life out of a battery.
Posted on Mar 02, 2009
    Novelist:
    Scholar:
  • 95 Answers
Hello, It is my experience that Toshiba laptops have problems with the plug receptacle on the laptop may have come lose. This receptacle is attached to the motherboard and can cause some real problems. The face that it says it is charging is unusual.
Another factor is the age of the laptop. A old battery can be the cause. From what your saying I would consider this highly as it will show a charge but the battery is not holding a charge and not working. I cannot be certain at this point but my best guess is to replace the battery and they can be expensive.
    Problem Solver:
  • 3 Answers
I think either something is wrong with the battery connection OR you have a dead battery. Your battery has a certain amount of life before it won't hold the charge. I have a battery over a year old and it's working fine. If it is the battery try using a new one on a site known as NewEgg. I don't know if it has it but it carries a lot of computer items so that's one source. Also, I recommend discharging the battery until the system goes into hibernation or whatever setting you use for low battery. I do this every three weeks. If you have more then one battery, rotate the use. Hope this helps. :-)
Posted on Mar 15, 2009
    Novelist:
  • 121 Answers
How old is the battery? Could be a bad battery. I know mine says its charged but as soon as I pull it off the power supply it shuts down. Order a new battery off the internet and see if that fixes the issue.
Armymason
Hp pavalion dv6550 runs on charged battery but not on adapter and does not charge the battery either. When the AC adapter is connected the blue light comes up so I'm assuming it is powered and con
Try another cord/charger with the EXACT same power specs as the original. Has the AC jack in the laptop been damaged, loose connection, due to pulling on the cord while plugged in? Try to wiggle it when plugged in to see if there is any connection. The AC jack may need replacing, if your lucky.
Apr 07, 2013 | HP Pavilion Computers & Internet
Battery won't charge
So put the old power cord back on since you say it charged the battery normally. Why did you change it if it was charging the battery? It's quite possible that the new power cord is faulty. Just because it is new does not mean it works.
Remove the battery and plug the new power cord in. Does it boot the laptop up? Are you able to function with the new power cord plugged in. If so, then your battery is more than likely dead and needs to be replaced. The battery only has a useful life and once it is completely bad it will not charge.
May 01, 2012 | Dell Inspiron 1545 Notebook
Hello,my laptop didn't get started it is charging
How do you know it is charging? What does it do when you hit the power button?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 30, 2012 | Computers & Internet
I have a DELL Inspiron Mini. The power LED light is alternately flashing white and red. The netbook will not come on unless I have the power cord plugged in. When I do plug it in and power on, the...
This could indicate a bad battery. Try removing the battery and powering on the laptop. If the power LED remains white then you have a problem with the charging circuit. That means your battery could be defective or the battery charging circuit on your motherboard is faulty.
Feb 21, 2011 | Dell Inspiron Mini 10 Notebook
I purchased a new battery, installed it and plugged in cord to charge. The charge light came on, it was on charge for about ten hour, This overnight that I charged the battery, the charge light was out the...
Some units will charge with the light on and when it reaches full capacity the light goes off preventing overcharging the battery. Now! you mentioned that the battery had charged, how long did the battery run? "should be around 2 hours" If you find the light comes back on to recharge the battery then this probably normal. But if the battery is ready to be charged and no light comes on, then it indicates the charging circuits in the motherboard is not working.
Jan 14, 2011 | Compaq Armada M700 Notebook
PLEASE HELP!! I am going on a business trip tomorrow and ALL of my requisite files are on my Dell Latitude D610 that won't power on. PROBLEM: once I removed it from my docking station at work, it won't...
When you say you "tried turning it on with the battery removed", did you leave it plugged into the wall with the charging adapter at the time? Please clarify that you tried to use it while plugged in without the battery and it would not power up? When you plugged it in without the battery, was the green charging light on? Or did you get no power light at all?
With your battery in, try using a different outlet to plug into. Plug it into another outlet and when the green charging light comes on press and hold your power button on your keyboard and do not release it for 30 to 45 seconds. Tell me if this boots up the pc even if just for a moment?
There are three lights on your keyboard that should come on when the laptop is plugged in and turned on. One is the power light, the other is the battery charging light and the last one is the hard drive indicator that looks like a round cylinder on the picture. Tell me when you plug it into the outlet and the battery charge light is on, does the hard drive light come on and/or flicker when you try to power up the laptop? How many lights come on when you press and hold down the power button with the cord plugged into the wall?
Jan 09, 2011 | Dell Latitude D610 Notebook
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
Powers on immediately powers off
ok well there is somwhere to start i would see if you can get it to take a charge ok and if it does than try to start it without the ac power on and see what it does if it wont take a charge your battery may be bad or your charging circuit may not be connected correctly ok lrt me know best regards mike
Aug 27, 2008 | Dell Inspiron 5160 Notebook
Dell D600
If the docking station is not charging the laptop while docked, it may simply need to be plugged in using the power cord to recharge the battery.
Jul 21, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
1,194 people viewed this question
David Payne
David Payne
