Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
My dishwasher gets hot enough, and runs good but half of my dishes come out clean the other half is still dirty and really really cloudy, what should I try? Will vinegar and baking soda help?
  • Anonymous Mar 02, 2009
    Is the arm supposed to spin when off?
  • Anonymous May 13, 2009
    Bosch - Dishwasher -the time left remaining keeps chaging. Starts off around 132 and then changes to 185. Also things on top rack are clean but bottom rack really dirty. Previoulsy when I opened the door after it had finished the itmes where still hot. Now they are cold
    Genius:
  • 2,120 Answers
I would say the wash arms aren't spinning, move them by hand and check for freeness.
Posted on Mar 02, 2009
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
Sounds like a hard water issue to me. there is a new product for this called the dishwasher filtration system. it is very affordable and filters the water going into your dishwasher. it will leave your dishes crystal clear after the first load. it is guaranteed to work and you can get it at www.dishwasherfilter.com.
Posted on May 21, 2009
Glasses int he top rack of my kitchenaid dishwasher don;t get clean. they finish the run spotted and covered in what looks like baked on dirty dishwater. dishes in the lower rack look ok, but the...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Jan 11, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
It' no longer cleaning my dishes
hello,
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
thanks.
Oct 23, 2010 | Dishwashers
Dishes are still dirty at the end of the cycle
hello,
hope this help?
thanks.
Oct 23, 2010 | Kenmore Dishwashers
Glasses dirty looking and cloudy after wash cycle.
If there is not enough water, the dishes will not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film, or cloudy look after the wash cycle.
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
Nov 16, 2009 | Dishwashers
Our glasses are really cloudy. How do we clean the inside of the dishwasher?
This may be a hard water issue, but assuming it's not:
Pour 1 liter of white vinager into your dishwasher and run through a full cycle.
If this fails:
Pout 1/2 liter of CLR into you dishwasher and run through 3 full cycles.
N.B. Vinager is preffered as it's non-toxic.
Other possible issues:
hard water, lime/sediment buildup in hot water tank, not using rinse-aids like "jet-dry"
Sep 08, 2009 | Maytag Dishwashers
Cloudy and dirty dishes after washing
I found this for you on YouTube. I don't think that you want to go to the extreme lengths that this guy did, but he does show how to disassemble the inside portion of your washer so you can get to the parts that need cleaning. This should get you back up and running, with sparkling dishes, and a big smile on your face! There are also oyher videos there, some selling products that may help.
http://www.youtube.com/watch?v=JhchaOhpQQo
Best regards, --W/D--
Aug 08, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Dishes not coming out clean
Check your hot water supply. It should be at least 125 degrees. Are the dishes spotty or still dirty with old food? Try to pre-rinse your dishes before putting them into the dishwasher. You can also run your hot water until it's nice and hot coming from the sink before turning your dishwasher on. If they're spotty, use less or better quality detergent. My guess is going to be water temperature or pressure.
Jul 03, 2009 | KitchenAid Dishwashers
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Bosch Dishwasher Wont clean properly
Poor cleaning is generally caused by not having enough water in the tub, which is usually the fault of the water inlet valve. You mentioned cleaning the filters... which filters? Did you remove the valve and clean its screen/filter? If that screen gets clogged with debris (and they do) it'll choke off the water supply to the tub.
Nov 03, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dirty dishwasher
there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishes. the dishes look dirty because your water has a lot of calcium and magnesium in it making them appear cloudy or dirty. the dishwasher filter reduces those minerals and my dishes look perfect now. no more dirty and grimy looking dishes. i also dont waste time washing them by hand before and after the dishwasher. hahaha you can get it at www.dishwasherfilter.com. use code DFMTEN and you will get 10% off. it fits right under your sink and is very affordable. you will be glad you bought this product. thanks
Sep 24, 2007 | GE 24 in. GLD5500L Built-in Dishwasher
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
192 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
