Question about Canon PowerShot SD800 IS / IXUS 850 IS Digital Camera
Image extremely overexposed and has horizontal banding
Canon PowerShot SD800 IS suddenly started overexposing images taken in lighted areas, whether outdoors, lighted stage, or under lights in house (somewhat with close-up flash) and any detail in the image has horizontal banding. Have reset all settings; same problem. Had not changed anything when it suddenly started.
  • rmcleran605 Apr 09, 2009
    Unfortunately, when I contacted Canon in early March the only option was to "trade-in" (with an additional charge) the camera on a refurbished "equivalent" model - not something I wanted to do because the "equivalent" model was the SD860 IS with no view finder. So now I'm stuck with a refurbished camera that in some respects is an improvement over the SD800 IS, but doesn't have a major feature that convinced me to buy the SD800 IS in the first place.
  • jpmartinezt
    jpmartinezt Oct 19, 2012
    My old, but still usefull Cono Pro 1, started to do the same problem today. Banding and some overexposed photos. I found that it only happens when I zoom out the lens between 50mm and around 135mm. When I shoot at 28mm or 200mm there is no problem at all.
    President:
  • 1,223 Answers
CCD failure !
but u are lucky canon is repairing it free of cost just see the link just call them they tell u how to send ur camera dont worry if u are not on list just call them
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
Posted on Apr 09, 2009
  • Shoaib Rais
    Shoaib Rais Apr 10, 2009
    but they shud replace the product without charge this is what they do if they are unable to repair the faulty product u can try again and ask them about repairs have u checked the link i provided
    see this as well
    http://www.usa.canon.com/consumer/contro...
My canon powershot g12 lcd works fine but the photos are all 'whited' out
You may have the exposure compensation settings overexposing you images. Since it compensates without affecting the image prior to shooting, you won't see it until after the image is taken. Check that and the flash exposure compensation too.
Jun 21, 2014 | Canon G12 Digital Camera
Canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear....and every time i take a picture...
The shutter flex cable inside the lens is broken. Happens to all cameras from Canon A4xx series. At day the images will be overexposed with horizontal lines on it, but it could look better at dark / night. The FLEX has to be replaced. Canon doesn't supply new flex cables for these, but there are some cheap copies on ebay. But as these brake very often, I wouldn't suggest you investing money in this camera, because it will brake again sooner or later.
Jan 26, 2011 | Canon PowerShot A470 Digital Camera
We have a canon powershot A410 digital camera with 3.2 mega pixels (purchased brand new in fall 2007) and recently, whenever we take pictures outside, they come out completely white (overexposed). The...
Hi there its a chance of sersor damaged. He not able to read the light. Thats why outside image are over exposed. I suggest you visit service center for check or repair the lens sensor.Thanks.
Apr 07, 2010 | Canon PowerShot A410 Digital Camera
Overexposure and horizontal-striped image
Hi!
No, it's not a software problem. The problem is that the shutter doesn't work so it can't control the amount of light taken so the pictures are very bright with horizontal lines. There are usualy two causes - a broken shutter cable inside the lens or the shuuter blades are stuck - may happen if the lens get wet or something adhesive gets in it. It's a hardware problem so I suggest you contact local Canon or other camera service center. It is considered a hard repair so it could get expensive. I don't think it's worth it, so I would suggest you get another camera.
Hope this helps!
Tom
Jul 29, 2009 | Canon PowerShot A420 Digital Camera
Canon SD400: horizontal lines and daylight images are overexposed (see photo)
In both the situations the problem is with the apperture control mechanism of the camera. 1). sometimes the flexible ribbion cable carrying signal to the lense assembly get worn out, replacing the same will resolve the problem. 2) in some cases the leaf blades of the apperture gets sticky, cleaning of the same solves the problem. 3). If you happen to drop the camera then the alignment of the motor moving the blades get disturbed.
In all the cases only a good repair man can fix the problem .
Jun 02, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Camera overexposes on daylight and recorded images have hoizontal striping
I would take it off of automatic mode and adjust it manually.
The Samsung camera I have doesn't work very well in automatic mode under indoor conditions. It will work in automatic under outdoor conditions.
Hope that helps.
Mar 24, 2008 | Samsung Digimax L60 Digital Camera
Canon Powershot Pro1
I also have the same problem and I took it to the canon service center. They told me that I have to replace the whole lens kit the problem was with the shutter not closing properly thus overexposing the pictures
Feb 26, 2008 | Canon PowerShot Pro1 Digital Camera
Taken pictures appear with horizontal lines
I have the same problem, this is my second cannon sent to me from them!
Nov 16, 2007 | Canon PowerShot A430 Digital Camera
Canon powershot
Repair shop or replace - unless you are into taking stuff apart but in this case it is a major component failure I feel
May 30, 2007 | Canon PowerShot S1 IS Digital Camera
Poor image displayed on cscreen after shot taken
I have an s60 and it sounds like I had this exact problem. Whenever I took a photo, the entire picture was covered with white horizontal lines. The actual image files were striped the same way.
I found this on the Canon USA site:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=223&modelid=10149
Because it was a hardware issue, they sent me a shipping label, I sent in the camera, they fixed it, and sent it back. All free of charge.
Good luck; I hope your camera is repairable.
Aug 24, 2006 | Canon PowerShot S60 Digital Camera
Canon PowerShot  SD800 IS / IXUS 850 IS Digital Camera Logo
259 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
