FixYa.com
Tags:
Da-Lite Da-Lite Tensioned Director Electrol 7 x 9-ft. - High Contrast Cinema Vision 89986 Projector Screen
Help! rear projection problem.
By LiZzIe - usenet poster
Okay, here's the dilemna. I have built a HT room in the basement. My
projector is a Sony 1270Q CRT. I've designed and framed the room to take
advantage of putting the projector behind the screen(about a 9ft
distance for an 84" diagonal). I did this to enhance the feel of a
theater and to eliminate proj. noise. After placing the projector
(directly behind the screen-recommended in the sony manual for rear
application) I am seeing the CRT's through the screen. I have yet to
purcchase the screen material,(I'm sitll in the rough-in stage) I'm
using a bed sheet to set the proj. up.
MY QUESTION..When the screen (probably a da-lite screen) is installed
will the CRT's still be visible? Mirror system is not an option --too
expensive. Help. thanks, Neal
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Ross
Ross - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
No you will not.. BTW do you sleep on a fresnel/ lenticular or diffusion
screen?
Gary Merson
Home Theater Perfection
ISF Authorized and Trained Calibrations and Optimizations for Standard and
HDTVs
Factory Authorized and Trained by Runco, Zenith and Vidikron for HDTV
Warranty Service and Optimized Projector Set-up (just factory trained by
Dwin for their Projector and Trans Scanner Set up)
Long Island NY's full time independent, dedicated ISF Calibration
SDTV/HDTV Optimization and Service Company.
Philips Color Analyzer, Philips Alignment Generator and ISF Optical
Comparator.
CEDIA Member- Serving the NY Metro Area-516-933-1128
See our classified ad in Stereophile's Guide to Home Theater
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Projection Televisions problems?
No picture with non HD
No picture with non HD channels... Answer This...
DLP Projection tv, Models...
DLP Projection tv, Models... Answer This...
yellow and blue shadow o
yellow and blue shadow o right... Answer This...
cant store code
cant store code Answer This...
Vertical red line on right
Vertical red line on right side... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
