Question about Generac Guardian 100 Amp Transfer Switch NEMA 3R
Generator will start when main power is loss, but will not shut down when power is restored.
Check your run timer
Posted on May 21, 2009
Have a Kubota A450-3-120 generator will start but won't run
The main jet in carb is clogged and needs to be cleaned out. It is starting on the fuel used for priming and once that runs out (almost immediately) unit will shut down for lack of fuel delivery.
Jan 15, 2017 | Electrical Supplies
Onan generator started to overcharge the battery and boiled out the acid
The circuit board that is under the start /stop switch on the generator has failed.
Nov 21, 2015 | Cars & Trucks
Kohler Generator won't start
If you have a drip leg near generator open that up for a sec and then try it again.
Nov 16, 2012 | Kohler Electrical Supplies
I have a Kohler 12 RES home standby generator. Once in a while when the power goes out the generator will start and then immediately shut down with no fault codes. When I flip the control in the unit
Check the inlet fuel pressure, on exervise there is no load, when power is out it is loaded and demands more fuel. Also check for bugs blocking gas regulators vents etc
Nov 12, 2012 | Kohler Generator. 12 kW and 14 kW Home...
Why does a propane generator shut down immediately after starting manually
Is this unit connected to a auto transfer breaker box. If it senses utility power the system may have to be run in test mode, or the main service breaker turned off.
Sep 01, 2011 | Electrical Supplies
I have a Generac Guardian 6KW Generator. The problem I'm having is that in Auto mode, the generator is starting up even with commercial power available. When we did lose power, I put the the gen in Auto...
John did you ever get this problem solved because I too am having a similar problem however for me it is also not shutting down automatically when the power is restored
Nov 09, 2010 | Generac 5680 GP Series GP8000 10,000 Watt...
Generac 4456 does not start on power loss
I install and work on these everyday. If you hooked up the transfer switch you probable have a control wire wrong. check the utility power sense wire. That lets it no when to start in auto. it could be a relay or fuses. or a control board.
Jul 01, 2009 | Generac Guardian 200 Amp Transfer Switch...
Generac Guardian 100 Amp Transfer Switch NEMA 3R Logo
101 people viewed this question
Top Generac Electrical Supplies Experts
 Kenneth
Kenneth
dennys23601
Don  Farrell
Don Farrell
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
