Question about GPS
The jack in the back of my nuvi 200 pushes in when
The jack in the back of my garmin nuvi 200 pushes in when i put the cord in so it will not charge
  • bhhemlock May 08, 2009
    does the unit need to be sent  in for repair  I would like to make the repair myself but not sure how the unit splits in half so I can solder  as needed  Thanks
    The charging port pushes in when i plug in the charger cord on my garmin 200 nuvi the port is soldered on the internal board from the response that I received. I would like to repair myself does this unit split in half so i can make repair or will unit need to be sent in for  repair
  • 277 Answers
Actually that component is soldered on the internal board and now its got moved from its position and the soldering has vcome loose.just get that component again soldered on the board to make it properly charge.
Posted on Mar 02, 2009
Can the unit be split in half so I can make repairs
Posted on May 08, 2009
Whenever I turn on my Nuvi 200 it shows the mass storage mode icon and will not display maps. How do I get rid of this problem?
With a Nuvi, If a Garmin or Garmin compatible power cord is not used, GPS will stay on the USB Mass Storage mode and will not go to Map Screen even though connector fits fine. In this case GPS can slowly charge. So, you need to find/obtain a power supply that works right.
Mar 22, 2011 | Garmin nuvi® 200 Car GPS Receiver
Garmin Nuvi 200 Favorites Backup and Restoration Procedure Models: Garmin Nuvi...
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Would you like to back up a copy of your Garmin Nuvi 200 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
Garmin Nuvi Hard Reset Here.
Download Nuvi 200 Manuals here.
Download Garmin WebUpdater here.
on Apr 17, 2010 | Garmin nuvi® 200 Car GPS Receiver
I just updated my maps on my garmin nuvi 255. now when i plug the charger in I cannot use the device while it's charging, i get the competer connect icon only. works fine if I disconnect it from a charger
This is a common problem with the 200 series garmin satnavs. It's caused by the mini usb plug of the power cord not being pushed fully into the back of the satnav. Because of the way it's designed it feels like it is fully in but it's not. Push it in further and the problem will be solved.
Aug 07, 2010 | GPS
Can not find a USB slot in my Garmin Nuvi 200
I can help you update your Garmin Nuvi 200.
Here is a picture of where the USB cord plugs into your nuvi:
These are the steps to take to update your Nuvi 200:
Download and then run Garmin 200 WebUpdater to replace its firmware / system software.
I hope that helps.
Backup your favorites.
Nuvi 200 Hard Reset.
Apr 21, 2010 | Garmin nuvi 200W GPS Receiver
My Nuvi 200 will not charge and the USB port
My condolences. I would suggest you plug the unit in to your computer's USB port using an appropriate data cable (in case you no longer have the Garmin data cable, there are lots of devices, including cameras, that use such a cable with the large USB plug at one end and the mini-USB at the other). That would give you a handle on where the fault lies -- in the auto charger cable itself vs the nuvi's socket. If the nuvi charges from your computer, you're halfway home; if not, I suspect the cost of repairing the nuvi's USB jack could exceed the cost of a replacement unit.
Mar 16, 2010 | Garmin nuvi 200W GPS Receiver
Garmin nivi 200 won,t turn on
The mini-USB jack needs to be either resoldered or replaced. When the jack is loose, you will not be able to charge the internal battery. The jack becomes loose from overuse. The jack needs more mechanical support to the pronted circuit board. I have fixed this problem many times.
- Jim
Aug 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
We have a nuvi 200. We can't find any cords or
I can help you fix your Garmin Nuvi 200W.
You can use the mini-usb to usb cord from many mp3 players or cameras with your garmin nuvi.
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
Jul 11, 2009 | Garmin nuvi 200W GPS Receiver
Id the Garmin Nuvi 200 supposed to function when plugged in?
Are you using the factory supplied Power cord or a standard Sony-type plug?
Mar 01, 2009 | Garmin nuvi 200 Car GPS Receiver
Without plugged in my garmin nuvi 200 will not work
That means that you have to replace the battery.
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Jan 21, 2009 | Garmin nuvi 200W GPS Receiver
Nuvi 200 -- won't power up after plugging into USB & Computer
Found out from Garmin Tech services how to reset the NUVI. Good to go.
Aug 05, 2008 | Garmin StreetPilot 2720 GPS Receiver
GPS Logo
167 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
