Unable to close the door - Televison & Video
  • 3 Answers
Give it a little light push. This is, of course, assuming you already tried pushing the "open" button, which often doubles as the "close" button.
Posted on Mar 02, 2009
I have a frigidaire professional, I am unable to close the oven door. I have a effortless oven rack systems
Good Afternoon Nancy,
I understand that you are unable to close your Frigidaire range door, model# FPGF3081KF. I would check to make sure that there is nothing blocking the door from closing. Make sure that the racks are in fully, and that the hinges on the door are not hindering the door from closing. If everything is fine there, make sure that the door locking mechanism is not engaged. If the locking mechanism is engaged, what you will want to do is press and hold down the oven lockout button for 5-10 seconds, while the door is still open. Give it about 15-30 seconds and the lock should retract. If none of these suggestions help, I would contact either the manufacturer or a local authorized technician for further assistance.
-Best Regards-
WP
Mar 27, 2014 | Frigidaire FPGF3081KF Stainless Steel Gas...
Hitachi ax-m71 cd door won't stay closed. Unable
if it opens back up when you close it the drawer mechanism is probably out of alignment. Most players have a slot on the bottom of the drawer that a pin must slide in. Look under the drawer and see if there is a pin sticking up that maybe should be in that slot.
Jul 09, 2013 | Audio Players & Recorders
Unable to close door
I have 2 different door problems with my 99 Park Ave: one door opens more than it should and often can't get it to move to close it and the other door opens but when trying to close it, the door will not latch closed. I'm not exactly sure what you mean by door wouldn't close, but with your mention of the metal parts, I'm gonna take a guess that it doesn't latch closed (kind of bounces back open too). For that problem I do 2 things to avoid actually fixing the problem. First, I check that the door handles are in the closed door position (my outside handle stays stuck out in the pulled position); I push them both in. If that doesn't work, I push down on the latch mechanism in the edge of the door to find that it was stuck in the open position. Once I do those 2 things, my door closes perfectly.
I hope this helped!
Jan 30, 2012 | 1999 Buick Park Avenue
My machine is showing the code FL machine has problems locking. How do I resolve this problem
Your Maytag Neptune Washing Machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
1.Check wire connections in harness leading from machine control board to door lock mechanism.2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
Dec 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Several times I have opened either of the two rear passenger doors, and then I am unable to close them. The latching mechanism won't allow the doors to close.
Usually the only time the lock changes to the closed position when the door is open is when you brush yourself or something against the lock mechanism.
Mar 04, 2010 | 2006 Ford Focus
Can't close rear doors after they have been opened.
have you locked the car before you close rear doors..if you have,you have the answer.....
Printer won't print - says door is closed, even when it's open
your door open sensor is not working proper.pls close this cover tightly..
Aug 16, 2009 | Office Equipment & Supplies
Motor is driving only one direction counter clockwise that closes
TRY UNPLUGGING FOR ABOUT 5 MIN.
THIS RESETS THE CIRCUIT BOARD.
IF THIS DOESN'T HELP TAKE OFF THE COVER AND LOOK AT THE LIMIT SWITCHES IT MAY BE RESTING AGAINST THE UP LIMIT - THIS WOULD TELL THE DOOR TO CLOSE - THE CHAIN MAY NEED TO BE SHIFTED - WITH THE DOOR FULLY CLOSED AND THE OPENER RESTING AGAINST THE CLOSED LIMIT REINSTALL THE CHAIN. & THEN RECHECK ALL ADJUSTMENTS
HOPE THIS HELPS
Dec 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
DOOR LOCKS(POWER)
your linkage has come off in side the door
Jul 29, 2008 | 1998 Ford Explorer
Televison & Video Logo
Top Televison & Video Experts
