Question about HP Compaq Presario 2500 HP Pavilion ZE 5000 NX9010 Series (chassis bottom)319470-001 (319470001) CD-ROM Drive
Cant log to desktop windows
Everytime i try to log to my desktop monitor goes to sleep mode or pc shuts off. i was told my pc is corrupted, what can i do.Also if hp has recovery discs or if i can order it?
  • 21 Answers
The best to do is take your computer to a technician to make a backup of your files and make a recovery or reinstall your computer.
If you try to make yourself you can lose all your files. Nad this could be more expensive than pay for a repair.
Posted on Mar 02, 2009
Monitor immediately goes to sleep. Tower shuts down from unplugging it.
have you tryed starting up in safe mode to see if you can get into your windows?
Apr 09, 2015 | HP Pavilion Media Center TV m8400f...
Windows sleep mode problems
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity
Dec 21, 2012 | Computers & Internet
Won't go into sleep mode
Which operating system ?
A menu opens.
Your Computer in sleep mode
First, save all of your work. Information in computer memory is not saved while your computer is on standby.
From the Start menu, select Settings, then Control Panel, then Power Management.
Click Standby Beside When I Push the Power Button.
Push the Power button.
Automatically Putting Your Computer on Standby
Save all work before leaving your computer.
From the Start menu, select Settings, then Control Panel.
Double-click Power Management.
Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks.
Click OK. Your computer will go on standby according to the schedule you have entered.
Putting Your Computer in Hibernation
Double-click Power Settings.
Click on the Advanced tab.
At the When I Push the Power Button On My Computer screen, click Hibernate.
Click the Power button.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
Sleeps and won't wake up. unblug pwr supply won't shut down properly. when pwr supply is plugged back in, monitor like comes on blue then amber like in sleep mode. Nothing shows on monitor. ctrl /alt/del...
Hello
Thank you for using FixYa for your problem
Needs a techie toolkit disc to run HDD regeneration scan then try the repair mode in your install disc, (2nd repair mode)
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Feb 21, 2010 | Gateway GT5625E Refurbished Intel Desktop...
Monitor goes into sleep mode as I'm working on it. How do I shut off/
How do you shut off sleep mode? I take it you're using Vista, as XP has "standby:" mode rather than sleep. You first right-click the desktop, then click "personalize." from there, click on "screen saver," and then "change power settings." from there, look on the left hand side of the window and choose the option you want to change. Probably, you'll want to "choose when to turn off the display." Hope this helps,
DH
Sep 22, 2009 | Dell E173FP 17" LCD Monitor
Sleep Mode Lockup on Dell Inspirion 530 w/ Vista
Try hitting the "Windows" key on your keyboard to bring it out of sleep mode. The "Windows" key is generally found on the bottom row of the keyboard, near the Alt and Ctrl keys, and it has no letters on it, just the Windows logo. That key brings my Windows Vista machines out of sleep mode when other keys won't.
As for the power button, anytime you need to force a computer to turn off, you can press and hold the power button to do so. Usually, you need to hold the power button for 5-10 seconds and it will shut down. Use this option with caution, as it turns the computer off without running through the shutdown process and can cause you to lose data.
Hope this helps.
Mar 08, 2009 | HP Media Center m7060n PC Desktop
Delay in Monitor display once the system goes in sleep mode
Instead of sleep mode, tyr hibernate. It is generally faster except the whole computer shuts down. When you power back up, you're exactly where you were. Mine takes about 30 seconds.
Feb 06, 2009 | Gateway Computers & Internet
Monitor goes into sleep mode after a few seconds
This is normaly cause by incorrect power management settings.
check power management setting in both windows and your computers bios
you will not need to worry about the power management settings of the bios when an operating system such as windows is loaded.
Loch Hiam
Az.
Sep 18, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Monito going to sleep
I have the same problem. Monitor states going to sleep and the pc goes dead
Jul 03, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Computers & Internet Logo
46 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
