Question about Emerson EWL3706 37 in. LCD Television
I have and old analog emerson tv EM-TV22031 i only see a vertical line in the center of the screen but it has sound, how i fix it?
    Problem Solver:
  • 18 Answers
The vertical ic or resistor,diode bad.take it by a good tech.
Posted on Mar 02, 2009
Emerson EWF2004 has a horizontal line in the middle of screen some color can be seen the rest is black. I disconnected cable, unplugged tv line remains how can I fix it?
This sounds like an analog TV. If so, the vertical oscillator or vertical drive output needs to be fixed. You will need a schematic to do the job.
Feb 25, 2015 | Emerson EWF2004 20" TV
I HAVE A LC401EM2F EMERSON TV 2 YRS OLD. WHEN I TURN ON THE TV I INITIALLY GET GREEN VERTICAL LINES, AFTER IT HAS FOR BEEN ON FOR A FEW MINITUES, THE VERTICAL LINES DISAPPEAR BUT A HORIZONTAL LINE APPEARS...
It sounds like a power surge has damaged the color controller and scan line section of the circuit board. The cost to repair is more then the replacement cost. Next time use a UPS for protection (battery back up for computer and electronics). Regards DaytonComputerDoctor@hotmail.com
Dec 18, 2013 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Vertical blue lines appeared on the screen with no sound.
All plasma an LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em. Good luck.
Jun 07, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Picture compresed to horizontal line in screen center
REPLACE VERTICAL IC & ASSOC. CAPACITORS
Apr 11, 2009 | Televison & Video
Picture junping
You possibly have a cracked solder joint in the vertical circuit, possible the vertical Ic itself. You'll have to remove the board and look carefully at the soldered connection of the vertical circuit and see if any are ring cracked. Some soldering should fix the problem. If you let the problem go too long the heat these cracks generate will eventaully short the vertical Ic..
Bill
Dec 04, 2008 | Emerson EWF2004 20" TV
Black Vertical line appeared on my Daewoo Plasma
Bad connection somewhere along the bottom or top of the panel, there are boards most likely along the bottom of the screen that control vertical drawing, a connection that breaks as it is heated up sounds about right. check the connectors along the bottom. Be very careful because if you wreck em the screen is junk. The connector that will be at fault will be in direct line with the black bar.
Oct 28, 2008 | RCA L26WD26D 26 in. LCD TV
Lighted line in center of tv
the trouble of your tv is not a picture tube.it's in vertical section,so check the supply of vertical IC if its ok ,re solder the ic.
Sep 30, 2008 | Emerson EWF2004 20" TV
31'sanyo tv analog has a white horizonal line thru it
There is a failure in the vertical amp section. This can be the main output IC, or any of the support components in this area.
An experienced tech can troubleshoot the set, and determine and service the fault.
Jerry G.
Apr 27, 2008 | Sanyo DS31590 31" TV
10 yr old emerson tv
The problem you are having is a vertical deflection problem. The screen is being compressed to a thin white line. It's probably a defective vertical output module or transistor. This part is not too expensive. Less likely would be a vertical deflection coil, which would be more expensive because its usually glued to the picture tube and harder to replace. You'll need to take your set to service center to have it serviced.
Good Luck!
- Jim
Feb 08, 2008 | Televison & Video
Tv trouble
MOST BE A VERTICAL PROBLEM if the line cross the screen from left to rigth,,, and if the line cross the screen from top to buttom then is an horizontal circuit problem any way you need a tech how ever if you know about tv repair and have somes skill in the campus try resoldering the vertical output IC....good luck and rate me
Jan 20, 2008 | Emerson EWF2703 27" TV
Emerson EWL3706 37 in. LCD Television Logo
87 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
