Question about Pioneer AVIC-D2 DVD Nav/6.5" Screen/AM/FM/CD Player Car Video Player
Speed sensor do i need to hook up this wire and what does it do
  • scott diorio Mar 07, 2009
    thanks i have a 97 dodge ram 1500 4x4
  • 33 Answers
The VSS or speed sense wire is used for navigation systems. The VSS wire sends a series of pulses (from 800 to just over 1,000 per mile) only when the vehicle is in motion. If the VSS wire is not hooked up, the navigation system will not realize that the car is moving at all, and will be unable to track position. If you need a wire color and location I can provide one for your vehicle. Hope this helps.
Posted on Mar 02, 2009
Got stuck in snow today, shortly after check engine light came on it says problem is the speed sensor? What is this?
speed sensor is what monitors speed & milage newer cars are electric older cars are cable operated check to see if wires are broken or plug is pulled off if not it probably needs replacing which is easy to do take bolt out along with clamp twist &pull sensor out &put new one in place put bolt &clamp back on reconnect wire plug & you are done hope this helps
Mar 03, 2013 | Cars & Trucks
Replaced the rear wheel speed sensor and re shimmed it out to spec. still cant get the speed to read and abs light still stays on. no broken or shorted wires possible sending unit issues or speed sensor...
remove sensor and look into hole, rotate wheel while watching speed ring for distortion. another way is to hook DVOM to wires and check for hrtz signal
Jul 08, 2011 | BMW F 650 GS Motorcycles
My traction control service light and ABS light comes on. What can I do to service it?
Hello Scurry.
When this happens the problem usually is one of the wheel speed sensors, connectors or the harness near the sensor.
ABS and traction control use the wheel speed sensors for information.
The system will need to be scanned by a tool capable of reading sensor output or the codes that will be stored due to the malfunction to pinpoint which one is the offender. Otherwise you will need to check each one on all 4 wheels.
You can check the resistance value at each sensor with a multimeter. Each one should read close to 1000 ohms. If they read OK then check the harness for open circuit, the wires often break near the plug that hooks to the sensor lead on the front sensors.
If you are handy with wiring repair you can cut out the bad section and resolder in a new wire.
If you need further assistance with this, leave me a comment.
Thank you for using FixYa.
KL
Mar 05, 2011 | Pontiac Grand Prix Cars & Trucks
Nissan Maxima speedometer reads 20 mph but actual speed is 40-50 mph, is my transmission going bad?
NO, IT'S NOT THE TRANSMISSION! SOUNDS LIKE A SPEEDOMETER PROBLEM! THAT WOULD BE ONE OF THREE THINGS! EITHER THE SPEEDOMETER, THE CABLE, OR THE SPEED SENSOR! THE SPEED SENSOR WILL USUALLY GIVE YOU A P0500 CODE ON AN OBD-II CODE READER! THE SPEED SENSOR IS ELECTRONIC SPEED CONTROL LOCATED ON THE TRANSMISSION! SOME HAVE A SPEEDOMETER CABLE HOOKED TO THEM, AND SOME JUST HAVE A 2 WIRE PLUG THAT HOOKS TO IT!
Mar 04, 2011 | 2000 Nissan Maxima
I need to hook up a centrodyne taxi meter to 2000 dodge caravan. I need to know how to hook it up. thanks
It's very easy on the pcm you will find a blue/orange wire. That's you hook up wire(vss). There are two set of wires off the meter bracket one comes with three wires and the other one with two. The one with 3 one goes to battery(red) ground(black) and top light(green or white). The other set of wires only the white one is connected to the vss.(vehicle speed sensor)
Sep 29, 2010 | 2000 Dodge Caravan
Just bought a 94 chevy blazer 4.3 vortex motor.digital speedo not working how do i hook it back up?
Your "speed sensor" is located on the transmissions tailshaft. It's possible the wire clip is detached, but usually the issue is a bad "speed sensor". There are a few different types of speed sensor for your vehicle year; depends on 2wd, 4wd, and vin#. It should be a easy fix, but speed sensors can cost a few bucks. I hope this helps you, and I wish you luck on your repair.
Aug 23, 2010 | 1994 Chevrolet S-10 Blazer
My 2005 trailblazer has check engine light on and the speedometer keeps going out
I don't see many bad sensors I would co to an auto zone read code if its a vss ck connevtors & wires at sensor does the trns shift if not ck the purpple & green wires
Aug 27, 2009 | 2005 Chevrolet TrailBlazer
Transmission Speed sensor wire on 06 Ford E-350
The older vehicles have a cable that hook up to left side of tranny. New vehicles have the speed sensor on the wheels and run to ECU then to speedometer
Jul 09, 2009 | 2007 Ford E-350 Super Duty Length XLT
Looking for wiring diagram
there is o actual single wire carying the vehicle speed signal to the cluster. the speedometer receives a signal over what is called the can bus system. the wheel speed sensors send a signal to the antilock brake module which in turns sends a signal to the pcm. the pcm then sends a signal over the can bus system to various controllers including the cluster. you can not tap into this wires as it will effect the entire system
Jan 08, 2009 | 2005 Jeep Grand Cherokee
Pioneer AVIC-D2 DVD Nav/6.5" Screen/AM/FM/CD Player Car Video Player Logo
290 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
