Jacuzzi pump won't shut off - Jacuzzi ALADDIN GO-KIT14 JACUZZI MAGNUM PUMP REPAIR KIT
  • Rod Kidman
    Rod Kidman May 11, 2010
    What model Jacuzzi pump? How are you trying to turn it on/off ? Is this a bathtub pump?
  • 3 Answers
The pump will not shut off until it reachs the pressure switch cut out setting. if the pump is converted for deep well with the injector in the well your not likely to get more then 40 psi. If the pressure switch is a 20 to 40 you might have to adjust the cut out pressure to 38 psi if the pump is making the maximum output pressure the line to the pressure switch is likely plugged. if that line is clear the switch is faulty,replace it. if the pump is not getting up to pressure the injector is likely plugged or greatly reduced.
Posted on May 13, 2009
Why do jets turn on, then shut off?
the motor protection device is sensing to many amps. could be a flow restriction or the pump motor bearings are going bad.
Mar 06, 2016 | Jacuzzi Home
I have a Jacuzzi low flow toliet. Sometimes the water won't shut off after it is flushed
A frequent cause of this is a defective flapper. If the flapper does not seat properly after a flush, the refill water will flow continuously
Feb 19, 2013 | Home
I have a Jacuzzi whirlpool bath model U640 Espree 536 and it wouldn't shut off. I cut the air line off at the pump and nbow it won't stay on for more than a few seconds. Any ideas?
I assume you hooked the hose back up to the air switch on the motor.
There will only be a couple of things to check.
Make sure you have a good connection with the air hose to the air switch on the motor. Sounds like maybe the air switch may be bad.
The Air Switch is a latching air switch so if is broken then it won't latch when the air button is pushed.
Jan 23, 2013 | Jacuzzi Home
Need to find local repair shop for my pool pump...not sure why wo't work
do a local google search online for a motor shop in your area.
sounds like the jacuzzi pump is bad. maybe a bad winding or bad bearing.
US Parts Center
Jul 19, 2012 | Jacuzzi Pool & Spa
Jacuzzi 1hp hums won't turn on
If your motor is turned on and just hums then it is bad and will need to be replaced.
US Parts Center
May 29, 2012 | Jacuzzi Impeller, L - 3/4 H.P
Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Sep 05, 2009 | Jacuzzi Signa Whirlpool Tub B540
Jacuzzi pump shuts off after short interval.
probably heater, alot of older spas/jacuzzi have a circulation pump connected to the heater. when the heater starts to heat and gets to hot or draws too much load - it shuts down.
this happened to mine and I had to replace the heater?
Sep 02, 2009 | Jacuzzi ALADDIN GO-KIT14 JACUZZI MAGNUM...
Pump won't shut off
You need a new impeller kit. Does any one know where to find one?
Jan 21, 2009 | Jacuzzi ALADDIN GO-KIT14 JACUZZI MAGNUM...
635 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
