Question about Goodman GMS90703BXA Heater
GMPN120-5 Furnace First of, old thermostat is installed. It was blinking and I replaced the battery. The reason I found out was it kept turning on/off. Second, thermostat is working and the fan comes on but not the heater. It goes thru a cycle. I adjust the temp. -> it clicks and heater starts but the burners won't come on. It works for about 20 sec. and then stops. Fan works but no heat.
    Sergeant:
    Novelist:
  • 277 Answers
Rth2520b Honeywell thermostat won't turn on
If known-good batteries were installed correctly, the thermostat may have failed.
Dec 23, 2013 | Honeywell Programmable Thermostat Heater
York diamond 90
The problem could be clogged hoses or hose connections or a bad pressure switch. Remove one wire from pressure switch start furnace as soon as inducer fan starts reattach wire if furnace runs replace pressure switch.hope this helps
Dec 11, 2013 | Heating & Cooling
On the thermostat the "filter"
Thermostats used in homes sometimes have a timer built in which will remind you to change your furnace filter. Most of them can be adjusted or disabled. The thermostat has no way of knowing whether the filter is actually dirty, it just reminds you every so often by flashing "filter" on the display.
It is possible to reset the timer, or adjust how often it appears, or disable it completely. Exactly how to do that depends on the make and model of your thermostat. Often, it is simply a case of holding two buttons at the same time for a few seconds.
As to why the furnace doesn't come on, there can be many reasons. The problem likely is not the "filter" flashing on the display of your thermostat. Try resetting the breakers that service the furnace unit itself. Make sure that the thermostat is set to "heat" and the setting is turned up. If the thermostat uses batteries (most do these days), replace them.
If this doesn't work, the following information will be helpful to get the furnace running again:
Brand
Model number
Age of furnace
Location in home
Brand and model of thermostat
Feb 28, 2011 | Heating & Cooling
My gibson furnace is about 8yrs old and it was working fine heat was on yesterday morning but last night it stopped. Changed batteries in thermostat which in new(thermostat) but no heat. Checked the vents...
Look on the back of the bottom cover... it should tell you what the blinking means...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Feb 03, 2011 | Gibson Heating & Cooling
I have an American Standard Freedom-80 Two stage furnace/AC. After replacing my old Honeywell with a new Honeywell RTH2310 thermostat (which the guy from A-1 Heating & A/C assured me was compatible...
The DS1 probably means dip switch 1. The light is used to give you different trouble codes. There should be something printed on the circuit board or on a label nearby that lets you know what each series of blinks means. I agree a good place to start would be to recheck the wiring then make sure you have the program in the thermostat right. It has several options.
May 02, 2010 | Heating & Cooling
My new honeywell T87N/T87K round is not turning on my heater
check for voltage then check connections sometimes the wire breaks and no power gets to the stat
Jan 06, 2010 | Honeywell Programmable Thermostat Heater
Vulcan gas wall furnace keeps turning off, and has err f1 on the control panel. Any suggestions? It is Sunday afternoon and about 8 degrees!
No idea what the problem is but - We have a manual vulcan gas wall furnace about 3yrs old and it has always been switching off since installed which is a real bummer on cold days. We had it checked out whilst under warranty but the technician did not fix the problem. Im not sure if it has anything to do with the gas supply but seems more of a product fault. Lucky weve got a combustion stove as well!
Jul 27, 2008 | Heating & Cooling
Carrier Infinity Control Thermostat SYSTXCCUID01-B
Your old stat is wired for a traditional thermostat and not a communication stat like the new infinity you have. There is a module plug on the furnace board that will need to be connected to the new thermostat for it to work. The wires that are wired now are from a terminal strip inside the furnace. Please contact your local Carrier dealer. They may be able to get that harness for you
Dec 06, 2007 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
225 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
