Question about Roper RES7646KQ Electric Dryer
Dryer won't start
I put a pair of tennis shoes in the dryer and after bouncing around a little bit the dryer quit, smelled a little like hot oil. Is there a reset switch or a fuse that may have burned?
    Sergeant:
    Novelist:
  • 277 Answers
Fuse ,,fuse ,, fuse.that has to be replaced.
Posted on Mar 02, 2009
Samsung front load dryer
it sounds like the problem may be with the door lock. Having shoes bouncing around in the dryer they are bound to hit the door over and over possible causing damage to the lock. Try pushing on the door and holding it shut while you turn on the unit and see if it works.
May 16, 2014 | Dryers
A pair of running shoes costs $5.00 more than a pair of regular tennis shoes. The total cost for both is $115 Find the price of the regular tennis shoes
You will never learn any mathematics if you do not solve math problems. I am here to do your homework. I will however help you set the problem up.
1. Define variables (unknowns).
2. Let t be the price of the tennis shoes
3. Let r be the price of running shoes.
Translate the text into mathematical expressions
A pair of running shoes costs 5$ more than a pair of tennis shoes
5 $ more ---> ... +5
Cost of a pair of running shoes (r) = cost of a pair of tennis shoes (t) +5
So the first statement can be expressed as r=t+5
The total cost of both ------> Sum of the costs r+t
The total cost of both is 115 $ ------> r+t=115
Now you have a system of two linear equations in two unknowns
( r=t+5
(r+t=115
There are a few methods to solve the system (comparison, substitution, or combination/addition/elimination). I gave the 3 possible names for the third methods.
Choose a method and solve the system to find t and r.
Note: Although all three methods, if carried out correctly, will give you the same solution (t,r), one of them should be preferred. It is worthwhile to recognize immediately which method should be favored depending on the system you are dealing with.
Oct 29, 2013 | Clothing Accessories
The dryer drum does not rotate at all. The dryer itself will "click" on when I push the start button and you can hear the dryer and feel the heat but the drum won't move. We took the entire...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 08, 2011 | Dryers
Dryer will not restart after tennis shoe getting stuck in it
Make sure door is closed firmly. Try to Press and hold the START Button for 4-5 Seconds.
Good Luck and have a nice day.
Jun 29, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer won't start
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 01, 2010 | LG DLE2532W Electric Dryer
Dryer drum stopped rotating, dryer blower continues to work.
The belt probably broke, and coincidentally happened while drying the shoes. The belt is easy to replace. Open the back and you'll probably see the belt laying on the bottom
Nov 10, 2009 | Bosch Axxis WTA 3510 Electric Dryer
The dryer just quit working. The last item dried in their was a pair of tennis shoes. Next day it won't even turn on. Checked the thermal fuse and jumped it but it still would not start, spin, etc. Help!
This may not be a solution but try testing the outlet its pluged into or the circuit breaker at the main box. Stranger things have happened.
Oct 03, 2009 | Dryers
I have a Neptune model MDE9700AYW dryer that wont start
Check to see if the little tab in the door jam, which causes the dryer to turn off, is broken or bent. If its bent you may just need to bend it back.
May 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune dryer won't start/
I do not have that specific dryer but try these simple steps.
Maybe they will help you.
1. Shut the electric breaker off to the dryer for about 30 seconds and and back on.
2. Open the dryer door and inspect the switch that tells the dryer the door is closed. work it by hand just to make sure it is not stuck.
3. Spin the timer controls to another setting and see if the other setting will work.
That's all I've got for now...
May 20, 2009 | Maytag Neptune MDE6700A Electric Dryer
TD 4112W Dryer does not auto reverse
my new dryer makes athumping sound when in use and it sounds like a pair tennis shoes are being dried
Feb 16, 2009 | Zanussi TD4112W Electric Dryer
Roper RES7646KQ Electric Dryer Logo
100 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
