Question about Lexmark Office Equipment & Supplies
Printer not ready Device is busy try again later. This is what keeps comng up when I try to print???????
    Sergeant:
    Novelist:
  • 277 Answers
Unplug the printer from the main power outlet for couple of minutes also dis connect it from the pc for that same time then again reconnect it and check it should work if still the same problem the driver of printers arte got corruppted so install the drivers again.
Posted on Mar 02, 2009
HP LaserJet 400 colorMFP M475dw + Scan to Email + Device is busy, Try again later
If I'm getting this right, your printer says "Device is busy, Try again later" when you try to Scan to Email ? Make sure your Scan to email-configuration is set up correct. Still no luck ? Leave the printer without power for 30 min. You can also try a factory reset. If nothing help, check if your printer is still under warranty HERE. If still warranty call your local HP support and ask for service.
Nov 04, 2013 | HP LaserJet Pro 400 color MFP M475dw -...
Computer says printer is busy - try later I can't see why it's busy.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 21, 2011 | Lexmark X1270 All-In-One InkJet Printer
My lexmark X4650 gives me a message that the network printer is busy when I try to print wirelessly. There is no other computer trying to print.
Make sure there are no print jobs stuck in the queue then unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Wait at least 30 seconds before plugging it back in. When the printer's ready, try printing again. If the problem persists, I suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Jul 14, 2010 | Lexmark X4650 InkJet Printer
Device is busy error
Check on the bottom right of the screen you will see a small printer icon.
Double click on the icon. That will open up the Print Queue.
Look at the print jobs. If one job shows as Spooling, click on the job and then delete it.
Don
Jan 18, 2010 | Lexmark Office Equipment & Supplies
Screen shows ready but can't print
ese follow these procedures carefully and i hope it will solve your problem.
● Check that all trays are correctly
loaded, adjusted, and installed in
the device.
● Using the computer, check the print
queue or print spooler to see if the
device has been paused. If there
are problems with the current print
job, or if the device is paused, a
configuration page will not print.
Also check the IP address associated with it if it is not connected directly. Make sure it corresponds with the one on the printer.
May 19, 2009 | HP LaserJet P3005n Printer
Cannot print
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Computers & Internet
Printer ot ready device is busy
i've downloaded the install disc twice, when attempting to print, i get the "busy at this time" and after troubleshooting on my own, i get a message that reads "no spooling".
Oct 20, 2008 | Lexmark X63 InkJet Printer
Infrequent use of Xerox Phaser 8500
The reason he told you that is because ;
if left on permanently the fuser unit has a lamp ( nowadays the newer ones use a ceramic) the lamp continually comes on to keep the fuser warm and ready for you to print.which may cause the lamp to burn prematurely, most business keep theirs on all day with out the sleep mode( too busy to wait to warm up),
But, when you use the sleep mode most models do not turn on the lamp ( if it does it only puts out minimal power) but keep the power ready, which is why when you go to print it takes awhile to warm up.
The lamps are very resilient and last several years before having to change.
Jul 17, 2008 | Xerox Phaser 8500/DN Printer
Problem printing a word document
Go to the printers folder & right click on the printer icon & select properties, under advanced click on print processer & change it to Winprint & Ntemf 1.008 & then try printing
Jun 04, 2008 | Lexmark X5470 All-In-One InkJet Printer
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
752 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
