Question about Goodman GMS90703BXA Heater
Carrier gas pack inducer motor
The heater functions properly when I wiggle the small black/white/red wires going into the inducer motor . I'm assuming they send the board a signal to open the gas valve and fire up the unit .
The center frame and bearing plates are not tightened up and it's trying to shake itself apart , so I'm guessing those wires are loose inside also .
If , when I remove and inspect the motor , it can't be repaired , where's the best place to get a replacement at a decent price ?
    Guru:
  • 462 Answers
Sounds like you may have a bad connecton at the end, which end? if you follow the wires out of the motor they sometimes go to a MOLEX whitish plug. The wires treminate in this plug with PINS sometimes these PINS dont seat or come loose in the plug. Pull the plug apart and check the wires comming in from both directions. If they wont push or pull out of the plug either way they are seated ok. Check for a bent PIN while have it apart. If its worse and this dosnt fix it or its the end going to the motor consult www.carrier.com for a dealer near you. DO NOT USE A GENERIC MOTOR on your furncae as I believe it is a 2 speed and most generic motors ar only 1 speed. SOme of these gaspack motors have a centrifical switch and if this is your problem again consult with a carrier dealer. The price of the motor is secondary to safety and longvity of your comfort investment. If I knew where you lived I could make a better recomendation.
A viberation could mean a HORNET nest (using mud for their nest) could have been in place and reciently came loose and fell into the fan on the motor. carefully remove the assembly and inspect it for bent fan or shaft or maybe plastic and broken or metal rusted out parts.
If you need more information I need to know a few more things. If this helps you r not please grade accordingly and help me improve. THANKS AND GOOD LUCK.
Posted on Mar 02, 2009
What does 3 flashing lights on the Red T Product Gas Furnace Mean?
Vac switch. pull door/find grey tube to induced draft motor/pull tube off/suck on tube to hear it click/if so you need to find a wire small enough to insert into motor tube being sure power is off before doing this. 112 to 16G will work. reatttach and power up to see what happens. Good luck
May 06, 2014 | Goodman GDS80904BNA Open Flame Heater
Changed inducer motor, now furnace will not ignite and gives code 31
since there is no model number to go by, let's go generic. Most inducer motors have some way of "proving" it is running to the control board. It may have a centrifugal switch in it or it may have use some type of air pressure switch. The centrifugal switch will usually have 2 wires other than the power wires and most of the time, go to the rear of the motor. The air switch usually has a small rubber hose that pushes onto it and is connected to the fan housing.
Aug 06, 2017 | Carrier Heating & Cooling
Where is a prseeure switch on a carrier furnace
Your pressure switch will be located in the burner compartment. You will see the inducer motor that comes on when it has a call for heat. That motor is mounted to the housing inside the furnace. From that housing, there will be a small rubber tube going to the pressure switch. They are usually metal or black plastic, and round in shape. If the pressure switch is malfunctioning, try taking the hose off of the housing, being careful not to damage the hose. Blow and **** in on the hose and listen for the switch to "click" in and out. If there is no sound, it needs to be replaced. Also clear the adapter where the hose connects to the housing with a small piece of wire or something similar. These things clog up all the time and your basically making sure everything is clear before going any further. Another thing that can make a pressure switch act up is the inducer motor not working. And you might check the flue all the way through the roof to make sure its not blocked in any way. Hope this information helps and good luck.
Jan 22, 2012 | Goodman GMS90703BXA Heater
How do you wire a dayton electric unit heater? Model-3e030,watts-15000, phase-3, motor amps-22, motor volts-120, heater volts-480, listed air heater-492b, cycles-60 ac.You have a...
red, white, and black will be your high voltage. Green will probably be for ground and yellow and orange go to the thermostat. I can confirm on Monday when I have access to manuals.
Oct 04, 2009 | Dayton Electric Heater
5 ton carrier. we changed the condenser motor and marked where the wires connected. Old motor had yellow and brown to capacitor. New motor has an extra brown wire with white stripe... I connected it...
The best way to wire that motor is to connect a separate capacitor to it. The brown and brown w/white stripe go to the capacitor. The black and red wires go to the contactor.
Aug 06, 2009 | Heating & Cooling
Need wiring diagram for a carrier 383kav11048075? im replacing the icm281 control module. gas furnace
There should be a wiring diagram on the panel of the furnace. In the box of the icm 281 is step by step instructions.
Maybe this will help
Take notes on your low voltage wires from the thermostat and condenser. W Y R C G. Write down what color wires go to above terminals.
On your high voltage wiring,
Take the black wire from the transformer and put it on PR-1.
Take the white wire from the transformer and put it on PR-2
Take the black power wire from the panel interlock switch and connect it to L1
Take the white neutral power wire and connect it to L2
Take the black fan motor wire and connect it to HI
Take the red fan motor wire and connect it to LO
Take the white fan motor wire and connect it to COM
Then reconnect your low voltage terminal wires to W Y R C G.
Thats it.
May 03, 2009 | Carrier Heating & Cooling
I am replacing the a/c blower motor and capacitor. The old motor has 1 brown wire to the capacitor, 1 yellow wire to the capacitor (the yellow then loops from the capacitor over to the wiring panel), 1...
Motor Wiring
Old Motor
Brown wire is Start
Yellow wire is run or Power
Black wire is High Speed or Common
The other two taps are speed taps, but you have a single speed application
And high speed is what you need ,that’s why there’s not any wires
on Red and Blue if high speed was to much then you would move the
Black wire to one of the other taps RED low speed or Blue Medinm speed
New Motor
White goes to the Yellow wire from the capacitor
Black goes to the Black wire you took off of high speed on old motor
Of course both Brown wires go to the capacitor and Green to ground
If a capacitor doesn’t discharge it doesn’t mean it’s bad
but the capacitors don’t last as long as they used.
Any time you put in a new motor always replace the capacitor
It will save you a lot of time and grief later on.
Apr 27, 2009 | Heating & Cooling
Just relpace a seized up inducer motor/flu vent. 3 red blinks
the diagnostic codes should be listed next to the wiring schematic on the inside of the blower compartment door. if the inducer motor was bad I bet you have a tripped flame rollout switch around the burners. look for a very small red button between two wires on a disk around the burners. push on the red button to reset the switck. this should turn your furnace back on.
Mar 28, 2009 | Goodman GMS90703BXA Heater
Heat not coming on carrier gas pack code 31
code 31 indicates pressure switch did not close or reopened during the heat cycle....1st thing to check is the inducer motor,,this is a small motor that turns a small blower wheel that draws the exhaust gases through the furnace and blows them into the vent pipe....1st locate the inducer assembly,,most easily identified by the small plastic fan blade that cools the inducer motor as it runs..1st turn off tstat and turn off furnace power switch..then turn on furnace switch,then set tstat to heat,set the temp above room temp by 5 degrees...remove the furnace front cover,locate the inducer motor,,if it isnt turning,but is warm or hot after a minute or so,likely the inducer motor is bad..if it isnt turning and isnt warm after 1 minute,then likely the main control board is bad,,not turning the inducer motor when it should,,,,,if the inducer motor is running,,then the pressure switch isnt closing,, could be a bad pressure switch but more likely there is a problem with the venting...some possible problems that would cause the pressure switch not to close in an 80% eff furnace [metal vent pipe] are: [1] a blockage in the vent pipe,base of chimney,dead bird at the furnace where vent connects to furnace or down inside the inducer assy,accessed by removing vent pipe from furnace....if all clear the chimney could be blocked up inside,,is the draft good when vent is removed from base of chimney?..if furnace is a 90%+ type [pvc plastic vent pipe],,then check the intake pipe at the furnace by removing it where it attaches to top of furnace..is the intake clogged with anything?..then check the intake and exhaust pipes outside for blockages,,including ice/frost/snow at the exhaust pipe outlet..
Jan 26, 2009 | Goodman GMS90703BXA Heater
I have a Pentair MiniMax NT 250,000 btu pool heater that fails to
Two reasons.
1. There is air in the gas line. Power down the heater and allow it to try igniting until lockout. If it locks out, repeat the process. Most lines will clear within 4-5 attempts to ignite.
2. A plugged burner orifice. Run a small pipe cleaner in the brass fittings on the burner tray. They may have small webs in them restricting gas flow.
If the unit is a Standard (STD on the plate inside) it has a flame sensor that may also be bad. That sensor is on the end of the single wire that is cloase to the ignitor wire near the burners. Also check for a losse ground wire on the heater.
Nov 24, 2008 | Pool & Spa
Goodman GMS90703BXA Heater Logo
281 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
