Question about Rocket ET300 MP3 Player
My mp3 rocket won't start.
When i get on it it says fatal error
  • Anonymous Apr 10, 2009
    every time i try to open, it says unable to access jarfile lib\MP3Rocket.jar
How do i put back file mp3 rocket win.exe file
The safest way is to re-install the program.
1. Re-download the installation files here:
MP3 Rocket
2. Uninstall the non-working version.
Uninstall or change program Windows Help
3. Install the re-downloaded version.
4. Open My Computer.
5. Locate the MP3Rocket.exe file. Double-clicking on this file should start the installation for the program.
Jul 23, 2014 | MP3 Rocket
MP3 rocket will not open. Says it is has a fatal internal error. How can I fix this??
Try re-installing the software, using the removal application. Sometimes the software ask if you want to remove, or repair. You can then select the repair option. That should correct the problem. If it still doesn't work or the problem crops again go for the remove and the re-install it.
Oct 02, 2013 | Computers & Internet
I just installed MP3 rocket on my macbook and it wont connect to the internet, it just says "starting connection" I went into my firewall settings and allowed the connection and I have re-installed it 3...
Actually MP3 Rocket has no Mac version. I have tried to install it on my Mac OS X Yosemite but failed. I can't run it properly, even couldn't finish the installation. So I turned Any MP3 Downloader for help. It just worked well on my Mac.
http://download.cnet.com/Any-MP3-Downloader/3000-2141_4-76171793.html
Also it has an article which has introduced how to find MP3 Rocket for Mac alternatives: http://www.anymp3downloader.com/mp3-rocket-for-mac-alternatives/
Oct 01, 2013 | MP3 Rocket
Mp3 rocket fatal error
Sounds like a hardware failure. one of the internal components is most likely faulty, is it under warranty? if so it's a good idea to send it back to the manufacturer
Apr 23, 2013 | Computers & Internet
Why can't I access my jarfile\MP3Rocket.jar
You are likely experiencing this error because of an error with the java files that are on your computer. You see, some part of the java installation is corrupted when you receive this type of error. Java controls all aspects of MP3 Rocket's functions, even starting up. When Java is corrupted, it appears that MP3 Rocket is broken when really it may not be. You cannot physically inspect Java to be sure it installed properly so you must first do an uninstall, a restart, and then the Java installation followed by the Rocket installation.
This should correct your problem.
Tom Miller
KD4DTK
Aug 19, 2012 | Computers & Internet
Why I'm I unable to access my Jarfile lib\MP3Rocket.jar
Tom Miller
Aug 19, 2012 | Dell Computers & Internet
Unable to access jarfile lib\MP3Rocket.jar
the error refers to a missing mp3rocket.jar file within the installation of mp3 rocket. i.e. C:\program files\mp3 rocket\lib. solution is: uninstall mp3 rocket and uninstall all versions of java and JRE from add and remove programs(XP) then restart. install a new version mp3 rocket and you will be prompted to download java again. once installed MP3 Rocket.exe should be restored
May 22, 2010 | Rocket ET300 MP3 Player
mine did the same thing about a month ago.
I just uninstalled it and reinstalled it again from the site.
don't worry all of your songs should still be there
Mar 02, 2009 | Digital Audio Electronics - Others
Open Questions:
i have downloaded mp3 rocket but when I try launch it it says one or more necessary files may be corrupt? MP3Rocket version 5.4.5 Java version 1.6.0_01 from Sun Microsystems Inc. Windows Vista v. 6.1 on x86 Free/total memory: 3680936/5177344 com.limegroup.gnutella.gui.GUILoader$StartupFailedException: file [vorbisspi.jar] has hash of [C02D434882D9212EE92A4D306FE01591] instead of expected [D840DAF0B8D76AE8F3B134647C38DF25] at com.limegroup.gnutella.gui.GUILoader.verifyHashes(Unknown Source) at com.limegroup.gnutella.gui.GUILoader.sanityCheck(Unknown Source) at com.limegroup.gnutella.gui.GUILoader.load(Unknown Source) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at com.limegroup.gnutella.gui.Main.main(Unknown Source) STARTUP ERROR! FILES IN CURRENT DIRECTORY: C:\Program Files\MP3 Rocket\games1.zip LAST MODIFIED: 1277914100000 SIZE: 90186 C:\Program Files\MP3 Rocket\intro6.zip LAST MODIFIED: 1279646410000 SIZE: 310877 C:\Program Files\MP3 Rocket\lib LAST MODIFIED: 1285579815552 SIZE: 16384 C:\Program Files\MP3 Rocket\License.txt LAST MODIFIED: 1277914100000 SIZE: 17719 C:\Program Files\MP3 Rocket\MP3 Rocket (Minimized).lnk LAST MODIFIED: 1285579807649 SIZE: 1900 C:\Program Files\MP3 Rocket\MP3Rocket.exe LAST MODIFIED: 1277914100000 SIZE: 174080 C:\Program Files\MP3 Rocket\MP3Rocket.ico LAST MODIFIED: 1279740030000 SIZE: 33982 C:\Program Files\MP3 Rocket\radio1.zip LAST MODIFIED: 1277914100000 SIZE: 165644 C:\Program Files\MP3 Rocket\resource LAST MODIFIED: 1285579789804 SIZE: 0 C:\Program Files\MP3 Rocket\root LAST MODIFIED: 1285579789617 SIZE: 0 C:\Program Files\MP3 Rocket\search6.zip LAST MODIFIED: 1279646410000 SIZE: 21942 C:\Program Files\MP3 Rocket\tv4.zip LAST MODIFIED: 1279646410000 SIZE: 290037 C:\Program Files\MP3 Rocket\Uninstall.exe LAST MODIFIED: 1285579815638 SIZE: 130573 C:\Program Files\MP3 Rocket\uninstall.ico LAST MODIFIED: 1277914100000 SIZE: 33982 C:\Program Files\MP3 Rocket\xml.war LAST MODIFIED: 1279740030000 SIZE: 17356
Sep 28, 2010 | Rocket ET300 MP3 Player
See all Rocket ET300 MP3 Player Questions
Rocket ET300 MP3 Player Logo
1,931 people viewed this question
Top Rocket Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Rocket Audio Player and Recorder Expert? Answer questions, earn points and help others
