Question about Mitsubishi WD-52525 52" Rear Projection HDTV
No power. No lights.
No power to TV. No lights.
None of the buttons work.
Lamp is intact and was properly working.
  • 3 more comments
  • jdboren Mar 24, 2009
    tv does not turn on, no lights, audio --no power.
  • exprtamateur May 16, 2009
    Same problem - no power no lights. No idea where to start. I live in a high-lightning area, but have an arrestor on the house from the power co. and a high end filter/surge protector.
    I've replaced the lamp once, been through the blinking green light of death - told it was bad capacitors, bad dm module, paid to have it fixed - continued to happen intermittently would have to unplug replug and reset in random combinations to finally get it to reset (learned to do that from a post - apparently it is some kind of sych issue with the DM Module) and I've had the bad light ballast - now this - which is NOTHING AT ALL.
    For a set that is only 4-5 years old and cost what this one did - Mitsubishi should be ashamed. I will never buy a Mitsubishi product again.
  • exprtamateur May 11, 2010
    I used to with the green light of death...not now it is d-e-a-d - DEAD!
  • Jeremy B May 11, 2010
    do you here any clicks when first plug in?
  • karibia edwards Jul 24, 2013
    yep...my tv same thing no power...freaking blinking lights...lamp replaced...still nothing!!!!
I have the exact same problem.
TV was working fine (if you call having to deal with blinking lights of death and multiple starrt up errors...) - but I powered through it all.
This TV is 6 years old and started acting up after the 4-year extended warranty ran out.
This morning I went to turn it on and nothing.
Hmmm... Got my manual to count the blinking light code...
Whoops. No lights. Nothing. Checked plug. Checked power.
Uninstalled and installed lamp. Checked plug and power again.
Nothing.
Not one stinking light. No power to fan. Nothing.
How does a TV just DIE???
Posted on Jan 24, 2011
Typically the power button blinks green for a few seconds before turning a solid green as the lamp lights up. Now the power button just blinks green indefinitely, without the TV ever turning on. I figured...
Hello Jeremy,
May be some IC or capacitor is damaged due to which TV is not turning on. Please contact the service center of the Sony. They will repair it properly.
Dec 26, 2011 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I have the Mitsubishi WD-65738 65-Inch 3D DLP HDTV I was watching it and it made a pop sound, then the screen went black what can I do.....
Tv "LAMP" LED light indication on the tv frame word light up or blinking LED light.Check the tv projection Lamp first.The tv projection Lamp might litterly broken into glasses sharts itself.The tv projection lamp still intact,still should be change too though.After the tv projection lamp has been change the tv should work now.If still have problems the board that call the Balast board probally dead too.Becauuse this Ballast board only jobs are to help to ignite and keep tv projetion lamp light up and to work only.
Sep 01, 2011 | Mitsubishi WD65737 65" DLP TV
I have a mitsubishi 62 in wd 62527 and the red lamp light came on and we unplugged the tv and reset the red button now no power
The red light usually means the projection lamp is bad. If you replaced it and the set still doesn't come on, then it is likely the ballast that drives the lamp is also bad. Also, if/when you do replace the lamp, make sure the access door to the lamp is fastened in properly. Other possibilities include a cooling fan failure and clogged air vents/filters. If none of these are the answer, then I would suspect problems in the power supply, usually stemming from defective capacitors which will require a technician with soldering skills to check out. Hope this helps.
Jul 10, 2011 | Mitsubishi Televison & Video
I have KDS-50A2000 Sony SXRD Projection TV. Serial #9028985. It was working fine then a few days ago I went to turn it on and the red power light was blinking 4 times and repeat... I then opened the lamp...
hello, this can cause the red power light to flash 3 time also if the lamp cover is not fitted securely this can also cause the light to flash 3 times 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped hope it helps
regards
shaun
Jan 03, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
MY SAMSUNG HLR5067WAXXAA PROJECTION TV JUST
replace the lamp only takes few min make sure you get right one for model of tv the LAMP MODEL number will be on OLD LAMP the tv will work and sound will come back hope this helps
Oct 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Same Thing Here
if your within 1yr, you can get a lamp replacement from mitsuparts.com or calling mitsu... make sure that you can get a redlight under the lamp and you already reset the TV.
Sep 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Just baught a new lamp and all that is happening is lamp light...
You will need to reset the lamp counter.
Begin with the TV powered off.
Point your remote towards your TV.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can subsitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
Jul 09, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Samsung TV about 4 years old, the tv turned off by itself last night and for whatever reason will not turn back on. When we use the remote the middle green light comes on in the middle as well when we use...
have u repleace the lamp yet , if not repleace, 4 years old would be a lot of hours the lamp may look intact but after severals hours tv start to go off
May 03, 2008 | Televison & Video
Power button blinking green
disconnect the power cord overnight try it if ok change power cord cheers
Dec 29, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
270 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
