Question about Akai LCT2701TD Television
No Picture or operation
I have a LCT2701TD and the red light on the front of the TV is blinking. The DVD player and the TV is not working. If I slid a DVD into the player it will not insert. I have tried different outlets and turned the TV off and on with the power switch and that has not worked.
  • rguti7 Mar 10, 2009
    I have the same problem, red light blinking, dvd or tv not working. I have unplugged and replugged, but no results.
  • 2,326 Answers
The red blinking light indicates a shorted part inside the TV. It normally happens when the power supply is trying to compensate the demand for proper or clean power to the rest of the boards. Most of these power supplies have defective capacitors and shorted zener diode(s) as well open surface mount resistors.
I repair these power supplies, if you need further assistance write to jah2mil@hotmail.com
Posted on Mar 30, 2009
I have bought an Antsig universal remote control for my Sony DVD CMT-GP8D but the 4 diget code is not in the operation book. Please help
Have you tried the manual option? Turn on your DVD player. Press "TV" or maybe a different button for DVD players, then a red light on your remote blinks once. Then hold both the "up" volume and "up" channel button down until your red light is permanently on. Then whilst holding your remote control 1mm away from your DVD player signal light (usually red too), hold down the "power" button until your dvd player switches off. Then switch it on again and try other buttons. However, I've only tried this on an LG TV, but took me 2 days until I really put the remote in front of that signal light. Took about 1 minute or more while holding down the "power" button. Hope it works =)
Jan 30, 2011 | One For All URC4110 Remote Control
MY 4YEARS AKAI LCD TV IS BLINKING ORANGE LIGHT BUT
Read the info from the link below to troubleshoot the failure with your LCD. Try not for force the LCD to work because for the time being it might only need the capacitors listed in the link but if the lights is blinking red, then the failure is a bit more complex to repair.
http://www.fixya.com/support/t3771079-lct2701td_t_v_will_not_turn_only
Feb 28, 2010 | Akai LCT2701TD Television
While watching the tv it stopped playing and a red
Are you still having trouble?Please let me know.Thank You very much!
Tyler
Feb 06, 2010 | Akai LCT2701TD Television
Will not power on, blinking red "power on" light
The power supply might have a shorted/defective diode(s), blown resistors, capacitors if the light is blinking on the front of the LCD.
I repair these power supplies, write to jah2mil@hotmail.com if you need further assistance.
Jun 24, 2009 | Akai LCT2701TD Television
BLINKING RED LIGHT AND NO PICTURE OR SOUND
The flashing light indicates a short circuit inside the power supply circuitry. This type of repair is not a DIY without a multimeter, desoldering iron and hand soldering skills. I repair these power supplies, if you need further info write to jah2mil@hotmail.com
May 27, 2009 | Akai LCT2701TD Television
Red power indicator light is blinking
May 26, 2009 | Akai LCT2701TD Television
Standby red light just continuesly blinks, no picture -
TV TURNS ON 1-2 SEC SCREEN SHOWS COMPONENTNT1 AND TURNS OFF WITH A POP SOUND FRO9M SPKRS
May 17, 2009 | Akai LCT2701TD Television
Akai LCT2701TD Won't turn on. Red light in front blinks.
There is a high power supply failure rate on these LCDs. The power boards are not longer being manufactured or not easy to find.
Write to jah2mil@hotmail.com for more info.
Sep 14, 2008 | Akai LCT3201AD 32 in. LCD Television
Flashing RED Light
Our AKAI also shut off & the red light started to blink...got no help from AKAI, but did from COSTCO. We bought the set before the 90 day warranty they have in place now, so they referred us to COSTCO Concierge Services: 1-866-861-0450. We were referred to a repair service & after discovering what the problem was found out that AKAI not longer has parts for this model. COSTCO replaced our TV---talk about satisfaction guaranteed.
May 14, 2008 | Akai LCT2701TD Television
AKAI LCT2701td TV No Picture
I had the same problem; the blinking light problem is caused by a bad power supply. It try’s to power up but senses a failure so it shuts down and just keeps repeating this process. I troubleshot the problem and found that zener diode Z3 (27volt 1 watt) was shorted and zener resistor forgot designation (2 surface mount 10 ohm resistors in parallel) were open. The zener is under a heat sink so it is hard to see. Also there were 4 1000uf capacitors that were bulging so I changed them as well. I got the parts from digikey for 20 bucks and its now working fine. This was a lower cost TV at the time of purchase so it seem the manufacture used low quality parts and I would suggest trying to return the TV to Costco before fixing it. Good luck.
Dec 24, 2007 | Akai LCT2701TD Television
Televison & Video Logo
242 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
