Question about KitchenAid Dryers
Advice on how to get fan off motor shaft on Kitchen Aid Gas Dryer
I have a Kitchen Aid Gas Dryer Model: KGYS750GQ1 that is having a motor problem.
I want to take the motor out of the Dryer chassis to bench test it but I cannot disconned the fan on the rear motor shaft.
I cannot find any documentation on how to get the fan off the shaft.
Is the motor shaft threaded and the fan screws onto it? Is there a special release mechanism?
Please advise.
Thanks Robo
    President:
  • KitchenAid Master
  • 2,651 Answers
No special tool, but it is reverse threaded!i usually place a vice grip over the plastic portion of the fan and with a monkey wrench onthe motor pulley im able to break the connection free, REVERSED THREADS gets me every time!
Posted on Mar 02, 2009
My kitchen aid dryer kgys758lq8 does not turn when drying its a gas dryer
First thought is broken belt or bad motor
Could be a relay or contactor that is bad that controls the motor too.
Aug 23, 2013 | Estate TEDX640JQ Electric Dryer
Kitchen Aid Dryer Gas/Front Loading Model KGYS750JQ1
Does the noise stop when you let off the start button? If so you either have a bad motor or something has gotten into the blower keeping it from turning. If the motor is running but drum not turning, you have a broken belt. Please post the complete model number from the dryer and I will try to help you with diagnosing and repairing the problem.
Thanks/Mike
Jan 07, 2008 | Dryers
Kitchen Aid Gas Range.Convection mode fan does not come on.Glow bare works,as well as the gas element.Flame is the proper colour.Could it be the oven sensor?Model nos.ykgst307hw5
Does the oven heat to the proper temperature and hold it there or does it not heat at all? I could not tell from your description of the problem.
Regards,Richard
Nov 08, 2011 | KitchenAid KGRA806PSS Gas Kitchen Range
Propane gas kitchen aid dryer is not heating. Model number KGYE660WWH1, dryer is over 14 years old, any suggestions to fix it? Spoke to gas company and there is no problem there...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 04, 2011 | Dryers
The dryer isn't drying. The dryer is a kitchen aid the model is kgye777bwh2. Also this is a gas model. I noticed that the pilot isn't lighting when I turn on the dryer. With the dryer running i...
heatman101;
Jul 22, 2011 | Dryers
Kitchen Aid Gas dryer KGYE664WWHI does not heat up
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at http://appliancehelponline.com/gdryertroublevideo.html this will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Aug 03, 2010 | KitchenAid KGYS850LT Gas Dryer
Kitchen aid dryer Partial drying the cloth
First you should make sure the exhaust vent and ducting and lint trap is not clogged or restricted, birds/insect nests, or lint build up. If the dryer is heating up it is most likely an airflow issue.
Jun 05, 2010 | KitchenAid KGYS850LT Gas Dryer
My kitchen aid gas dryer is not heating up.
If it is tumbling. This troubleshooting video will help. Could be the thermal fuse,ignitor,or gas coils. The free video will walk you thru testing.
www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | KitchenAid Dryers
Kitchen Aid Electric Dryer Model # KEYE678BALO, won't start.
This is most often caused by a bad thermal fuse or thermostat high limit cutout. Check them for continuity (with the machine unplugged, of course) They should have continuity -- replace them if open. They should be available at www.appliancepartspros.com Also, if one or both are bad, check the dryer vent as they often are damaged by high heat due to a restricted vent pipe. The website above also has diagrams to help find the parts on the machine.
Dec 30, 2009 | Washing Machines
Open Questions:
Dryers Logo
126 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
