Question about Soundstorm 2000W MOSFET 4 Ch Amp w/Remote F4500 Car Audio Amplifier
Car system was working fine and now the sub woofers do not have any sound coming out of them. I have replaced the subs, wires, terminals, and fuse, what else am i missing or is it something else?
    Problem Solver:
  • 18 Answers
It could be the sub botten on the e.q or your hand change some settings on the deck or e.q.
Posted on Mar 02, 2009
RCA RT2770 Sub-woofer sound doesn't come
The sub should generally have its own power supply, is it plugged in ???
Feb 16, 2016 | RCA RT2770 Theater System
My powered subwoofer no longer works through the receiver
if you have your front and centers set to 'small' you want your Bass out to be subwoofer only, and the rca jack labeled 'sub out' is the only place to connect your sub to if you want to control the frequencies with your reciever. I dont know the brand of your sub, or the inputs on the back of it to advise you where to connect, but it sounds like it worked for you at one time, but suddenly it does not
Mar 05, 2013 | Audio Players & Recorders
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
I have connected all speakers but not getting anything coming through the subwoofer? I have connected all of my existing Sony suround system speakers 4 corner and one middle and the sub woofer to the...
You need to use an amplified sub. The Yamaha receiver is only sending "Pre-Amp Signal" not amplified audio like the rest of your speakers. If your sub has a crossover built in, connect it's speaker level (wires) to the "B" side of the receiver which will send audio to your sub and it will cross it over internally. Not the best sounding, but it works. Amplified subs range in price from 200 and up. Hope this helps
Jun 14, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
No sound coming from sub woofers amp is connected and powered properly,all connections are correct,i have checked all connections to head unit,to battery i have disconnected and re connected all...
check your amp fuse also any car fuses, then check inside the sub box at the connections as they dont come connected when you buy it, try that 1st
Jul 11, 2009 | Car Audio & Video
Amp powers on but sub does not come on
I would double-check your RCA's on the amplifier. You should hear a thud if you unplug them. If not they are either not hooked up or defective.
Feb 07, 2009 | Sony XM-2150GSX Car Audio Amplifier
Could a ground stop your woofer from working?
First check the speaker wire from the amp to the sub, see if it's connected right. Second check the rca cables that goes from your amp to the back of the deck. I f both wires are still connected fine try to replace the rca cables. If it still doesn't work the rear out put at the back of your deck, where the rca's are connected are bad. FYI deck is bad.
Nov 29, 2008 | Jl Audio 12W3 Car Subwoofer
TH-M606
Either the amp for the sub is bad, or the sub woofer speaker is bad. If you checked the fuses, you must know how to get the amp out of the sub woofer box (screws in the bottom of box and around the metal plate of the box). Take it out again and check the wires that go to the sub woofer. It is the red and white wires if I remember correctly. They come from the box and plug into the amp board with a white plastic connector. Or you can check the wires right at the speaker. The cover for the speaker comes off with about 4 phillips screws and then take the speaker out with the screw driver as well.Use an ohm meter and check the ohms on the speaker at those wires after you dis-connect them from the board. That woofer should measure between 3 and 6 ohms to still be good. If it measures less than 3 ohms or more than 6 ohms, it is probably bad and will need to be replaced.
Here is the JVC part number for that woofer.
CR250006-01
Be prepared, the cost is ridiculous. $110.16 at JVC's service site.
http://www.jvcservice.com/Service/JPartInq.asp?PgReq=DspDta&PrtNbr=CR250006-01
Or you could just find one that fits properly and use it instead. They are not the best woofer around and are very over-priced.
I hope this helps, if so a FixYa! rating would be very much appreciated. After all, it is the only reward we get for offering free help to people like yourself.
Dave
Aug 12, 2008 | JVC TH-M606 System
JVC TH-M606
You need to take apart tthe sub woofer and check the connection to bass speaker for continuity. It sounds like an internal broken connection to speaker on sub woofer unit.
Soundstorm 2000W MOSFET 4 Ch Amp w/Remote F4500 Car Audio Amplifier Logo
51 people viewed this question
Top Soundstorm Car Audio & Video Experts
Coss
hoyzee1
Are you a Soundstorm Car Audio and Video Expert? Answer questions, earn points and help others
