Question about Adobe PageMaker 7.0 for PC
I am using Pagemake 6.5....44 pages. I could not print to the Epson printer. Error report: "Cannot Process Publications Links. Internal Error: Bad Record Index....8901:20515" There is only type and 3 charts made in pagemaker in these pages. I split the 44 pages in two secontions. First pages 3 to 31 printed OK. Can't get rest printed. HELP
  • 6 more comments
  • info162 Mar 02, 2009
    I've saved the files. Restarted the computer and printer....and still can't print the text pages.
    More help. Please
    Remember i am on a MAC. Printer is an
    EPSON C82.
    I can usually print-out 60 pages at one time. As indicated earlier, I've split the file in half, then quarters, but can only print pages 1-31. Please offer more advise. Thank you. Nickname & Password:info162...dcaad
    More advise plz
    EPSON C82.
    more advise
    more..
    more..
    thnx
  • 1,800 Answers
Uninstalland installl drivers
then print teh printer automatic test page that would refresh the internal memory of printer then try again
Posted on Mar 02, 2009
    Scholar:
  • 150 Answers
Try printing only 5 or so pages of the project at a time. The printer only has a certain amount of RAM, and you are most likely overloading it.
Please remember to rate if this helps, thanks!
  • 10,515 Answers
Download Scribus...
http://www.scribus.net/
Copy the above address, paste in browser and enter.
I installed Scribus from ..., remade the document in it, and soon it generated PDFs and files for publication, for graphics, IT WORKS very well excellent ..
it's clear that Adobe reccomends to move on to In_Design but, apart of the additional cost, we must remember the hundreds of files we have and that we will probably loose...
... certainly there will no longer be adequate support for our need for development, not even a concern about compatibilities and the endless hours we have spent producing documents
Well, it has been commented for years now that PageMaker is an obsolete program. It's all right for you to rant, but you certainly knew what you were doing when you kept on using it despite the many warnings.
    Sergeant:
    Novelist:
  • 277 Answers
the printer has a software error ints board. try reinstalling the software if that helps your luck.but if not its possible that the board is got corruptted and showing this error as you will have to get it repaired.as in epson the reparing cost of the board will be as new boardso its quite advisable if the driver reinstallation does not helps just get the printer replaced if under warranty or go for another printer.never ever bye epsonn and canon printer only but HP printer.they are long lasting printer and always the reparing cost is negligible.
thanks.
  • 564 Answers
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Hope this helps!!! Thanks!!!
PREM
    Scholar:
  • 85 Answers
Try resetting the pages again and give print out for per page do not give print all command.as its getting hanged due to over load.just give print command for per page 1 by 1. and it will print.as many a times this happens.doing this solves the problem.then again next time it does not comes.its due to so many page overload print out given together.
    Scholar:
  • 165 Answers
Unplug the printer from power outlet and replug it again and try printing again.if it still has problems,reinstall the drivers. thanks and do rate the solution.
    Brigadier General:
  • 8,619 Answers
Hi
Please save the copy you are working on and then restart the computer and your printer & then try to print the pages.
  • 1 more comment
  • Rylee Smith
    Rylee Smith Mar 02, 2009
    You need to remeber these precautional steps---
    1.In Preferences, make sure "Save smaller" is checked.
    2. Try to keep files small--30 pages or so. Divide longer projects into shorter files.
    3. Be careful to be consistent when you apply styles in Word for
    documents you will be importing into PM. Don't create two different
    styles with the same name.
    4. When typing directly into PM, always assign what you type one of your styles.
    5 Never click-create a text block in PM without typing something, a space, at least. THEN you can delete it.
  • Rylee Smith
    And you can repair your document by---
    The first time you get the error message, save the document as another document. The new copy may be fixed.
    Hold down the shift and option keys while choosing Hyphenation.
    The document will be searched for problems. One beep means no problem, two means a problem or problems was repaired, three means an unrepaired problem. This is the only solution offered in the User's Manual, and doesn't seem to work very often.
    Command-click on each style name in the STyle palette to bring up the Edit styles dialogue box, then hit Return (or press OK). If you get anerror message with one of them, you've found a corrupted style. Thencommand-click on "No style" and type the name of the bad style, exactly, except for any plus signs or asterisks). Use save as.
    Find any temp files with names like "aldtmpXX" (where XX are sequential numbers) and open them with PM. They may be earlier versions that are not yet damaged.
    If you have linked text or graphics, go to Links in the File Menu and break all links to the original.
    Follow the instructions below in the section called "CompuServe
    BADRIX.TXT" to remove any corrupted styles.
    As a last desperate measure, create a new publication and copy and paste your stories one by one from the old publication; though if the old pub was created by placed stories created elsewhere, it might be almost as easy to recreate the document from scratch, which doesn't allow two documents open at once.
    Please ask for further clarifications.
    Thanks
    Rylee
  • Rylee Smith
    Also see these links for further refrences---
    Pagemaker Errors(on mac)
    Pagemaker Troubleshooting
  • 19,396 Answers
Try reinstalling the printer drivrs.
  • Ginko
    Ginko Mar 02, 2009
    You can try reinstalling the printer drivers, if that cannot solve the problem it may be because the printer has not enough internal memory to process the file.
End of service for epson wf 7610
If your Epson WorkForce WF-7610 printer shows error message "The Printer's Ink Pads at the end of Their service life" and Epson WorkForce WF-7610 printer has a red light blinking problem: You should be download and reset Epson WorkForce WF-7610 printer Waste Ink Pads Counter with Epson WorkForce WF-7610 Resetter.
Go to this link, you should be able to download the resetter and follow the procedures step by step.
Reset Epson WorkForce WF 7610 End of Service Life Error message Wic Reset...
Jul 22, 2017 | Epson Office Equipment & Supplies
Printer error
Here a few common problems that your Epson printer and ink cartridge can suffer from.
Improper Installation of Cartridges
A common Epson printer and ink cartridge problem! If you have changed the ink cartridges then you might just receive this error message. The message might state that the cartridge is not installed correctly in the printers. In such cases, re-install the cartridge in the correct manner. If the problem persists then it is advisable that you replace the cartridge as it might be defective. If you still get the same error message on installation of the replacement cartridge then its time that you clean the print head. You could do this yourself or could take it to a repair facility.
Printing Failure
Failure to print documents is yet another common problem with respect to Epson printers. The print heads of Epson printers are sensitive and this sensitiveness is the culprit behind such problems. If the print head is clogged or blocked you will have to unclog or unblock them. This can be done by using a special fluid that is available for just this purpose only. This fluid flushes the print head, and your printer is once again ready to print.
Communication Error
'Communication Problems' are yet another one of the common problems surrounding Epson printers. Once you give the print command you might be shown the message that there is a communication error between the printer and the computer. This means that there is the occurrence of a minor problem. One of the reasons for this problem could be the inappropriate selection of printers from the print options menu. Cable connections should also be checked. Another solution could be the re-installation of the driver of the printer.
Print Jobs that are Slow or Incomplete
These are problems that occur during an ongoing process. The printing might stop midway and then start again after some time. At times, the printing process will repeat itself several times and then finish printing the page. There are times when the page will finish printing, but you will find that it is an incomplete print. More often than not, this is not a printer related problem.
What might have happened is that the driver might have corrupted or a virus might have infected the computer; or a spyware might be affecting the working of the printing process. If such a problem occurs, the best solution would be to scan the computer for viruses and spyware. As can be seen these common Epson printers and Epson ink cartridge problems can be sorted out quite easily.
hope it helps..
Thanks for using fixya...
Dec 04, 2010 | Epson Office Equipment & Supplies
Printing blank pages
To mutch time the printer stopped. first check ink level, and use clean internal program
Oct 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Problem in printing character mode report on epson fx 2175
first take printer setting ...... press online botton( paper feed botton i am not sure which one ) and switch on the printer it will print all setting... ckeck any tear off setting is there .... off the option ....fallow the instraction to change any settiing .....
Oct 14, 2009 | Office Equipment & Supplies
Datamax WS6308 print error in .net
El controlador de Seagull es muy bueno y con muchos parametros, intenta modificar los parametros del spooler. Seagull driver is very good and with many parameters, try to modify the parameters of the spooler. buscar
Nov 24, 2008 | Epson Printer
Epson Stylus C42
Click on start, control panel then double-click printers and faxes. Double click the printer icon and you will see the printer queue. Click on Printers then Cancel All Documents. When all documents are gone from the print queue, restart your computer and switch your printer on. Click on start, control panel then double-click printers and faxes. Right click the printer icon and click on Properties. Click on Test Print. Check the print is OK. If not, report back.
Sep 23, 2008 | Epson Stylus C86 InkJet Printer
Epson DFX 8500
the file maybe too big to process, try printing the file in different method, like separating the sequence, divide the prints into parts in this way spooling will be easier and it will be queued anyway and will print, just be mindful of pages and sequence
Aug 08, 2008 | Epson DFX-8500 Matrix Printer
Sript, setup and internal error
try uninstalling all the printer software once you have done that then reboot and reinstall
Apr 06, 2008 | Epson Stylus C46 InkJet Printer
Adobe PageMaker 7.0 for PC Logo
61 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
