Question about Brother HL-2040 Laser Printer
Drum replaced light keeps flashing - Brother HL-2040 Laser Printer
When the print quality deteriorates and the drum light is flashing you can replace teh drum but the light will continue to flash until you reset it. Do this by opening the front of the printer and holding down the Go button for about 4 seconds until all four lights on the display are illuminated. It should be fine after that.
Posted on Jun 17, 2009
    Sergeant:
    Novelist:
  • 277 Answers
The sensor which detects the drum is getting blocked internally that needs to be readjusted.
Posted on Mar 02, 2009
I've replaced the toner and drum. Now the drum light keeps flashing. How do I reset it?
Try this
After replacing the drum unit, keep the front cover open (make sure the power is on).Press and hold the “GO” button until all four LED’s are lit.Once the four LED’s light up, close the front cover.Make sure the drum LED is off.The counter is reset!
Aug 11, 2010 | Brother HL 5150D Laser Printer
My drum light keep flashing. How do i fix this problem?
if the drum light is flashing, and the ready light is on,
it means that your drum is nearing end of life and will need to be replaced soon.
thanks adi
Jan 26, 2010 | Brother HL-2070N Laser Printer
Brother HL5250DN PRINTER THE DRUM LIGHT KEEPS ON
it has a drum sensor ,it was disable to work but it look like new please change ot replace drum unite not only drum total unite then solve your problem
thanks Tareq
Nov 11, 2009 | Brother HL 5250DN Laser Printer
Drum light still on when toner has been replaced
You need to replace the drum and reset the printer for that to go away, open the front door and hold the go button til all lights flash and the drum is reset. If quality is OK you can keep using the old drum. If you press the go button 3 times it will give a report showing the life left in the drum.
Oct 01, 2009 | Brother HL-2070N Laser Printer
Brother HL 2040 drum light flashing after drum replacement
The drum light is triggered by a page counter. To reset it, hold the GO button with the drum door opened until the light goes out (10 seconds). Close the door and it should be reset.
Aug 07, 2009 | Brother HL-2040 Laser Printer
HL2140 - DRUM REPLACED APPROX 3 WEEKS AGO, LIGHT KEEPS COMING ON
When you replace a drum in a brother machine you have to tell the machine it's a new drum. The instructions are on a sheet packed with the new drum. With the front door open you hold the panel button until all the lights flash on, then close the door and you're ready to print.
Jun 23, 2009 | Office Equipment & Supplies
Yeah, I have the HL-5250DN printer. The light
Hi there -
The reason the drum light keeps flashing is that you have to "reset" the machine after you've installed a new drum. To do this, I believe all you have to do is make sure the printer is on and then push and hold down the "GO" button a few seconds and then the flashing will stop. This will "reset" the printer to recognize you've installed a new drum. I'm going from memory on that, but I believe that's correct. It's a really simple solution. Good luck!
May 15, 2009 | Brother HL 5250DN Laser Printer
Drum light will not go off
Open front cover of the printer, Press and hold down the GO button until all the LEDs light up, once all are lit release to GO button
Mar 18, 2009 | Brother HL 5250DN Laser Printer
DRUM LIGHT KEEP FLASHING
Take the drum out and wrap it up to keep the light out of it.  Check the contacts inside the printer and make sure there is nothing broken on them.  If there is toner on them, try to clean them off.
Oct 06, 2008 | Brother HL-2040 Laser Printer
Drum light
Drum light reset below
Open cover
Press and hold down Go button for about 4 seconds until all the LEDs light up. Once all 4 LEDs are lit, release the Go button
Close cover
link to MANUAL
Dec 10, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
529 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
