Question about HP Deskjet 6980 InkJet Photo Printer
My HP Deskjet 6940 printer won't print
My Deskjet 6940 printer will try to print when i press the system check button, but in the middle of the print cycle, the deskjet's power and resume lights will begin to blink. When I press the resume button, my printer will just throw out a quarter-way completed system diagnostic sheet. Plz HELP!!!!!
    Sergeant:
    Novelist:
  • 277 Answers
The printer needs servicing.the steel rod on which the cartridge carriage moves sometime oiling that steel rod makes it proper other wise the whole printer needs to be opened and the cleaning and servicing needs to be done.
Posted on Mar 02, 2009
Hp deskjet 948c. What Do The Button's Do
buttons and lights The HP Deskjet printer buttons let you turn the printer on and off, cancel a print job, or resume printing. The lights give you visual cues about the state of the printer
sayurisan20_33.jpgcancel button
print cartridge status symbol and light **The light above the Print Cartridge Status symbol flashes when a print cartridge is low on ink or incorrectly installed.
sayurisan20_35.jpg resume button and light
**The light above the Resume button flashes when an action is required such as loading paper or clearing a paper jam. When the problem is fixed, press the Resume button to continue printing.
sayurisan20_36.jpg power button and light **
The Power button turns the printer on and off. It takes approximately five seconds for the printer to turn on after you press the Power button. The green light above the Power button flashes when printing is in progress. Caution! Always use the Power button on the front of the printer to turn the printer on and off. Using a power strip, surge protector, or a wallmounted switch to turn the printer on and off may cause premature printer failure
Jun 17, 2011 | HP Office Equipment & Supplies
My hp deskjet 6940 inkjet printer doesn't show me level of ink in cartridge
Print a diagnostic page If the steps above have not helped, print and evaluate a diagnostic page to see if the cartridges or the printer is causing the problem.
  1. Make sure the printer is on and loaded with unused, plain, white paper.
  2. Press and hold the Power button and then press the Cancel button. Release both buttons. The diagnostic page prints. Figure 1: Power and Cancel buttonsc00584735.gif 1 - Cancel button 2 - Power button
Step 4: Note which cartridges printed which areas of the diagnostic page You must identify which cartridge printed which part of the diagnostic page, so that if you find defects on the page, you will know which cartridge is the problem. However, you can install different combinations of print cartridges in your printer, and different cartridge combinations print different diagnostic page patterns. Your diagnostic page may not look exactly like the picture below, but the right and left cartridges will print in the same areas of the page no matter which cartridges are installed. Figure 2: Diagnostic page layout (the patterns in each area may look slightly different on your page)c00584715.gif 1 - Printed by the right cartridge 2 - Printed by the left cartridge NOTE: If you are printing in reserve mode (one cartridge is missing), the missing cartridge's area of the diagnostic page will be blank. Step 5: Check ink levels NOTE: If you have installed a refilled or remanufactured ink cartridge, or a cartridge that has been used in another product, the ink level indicator is inaccurate or unavailable. Look in the middle of the diagnostic page. The bars with "E" (for "empty") and "F" (for "full") at each end show the ink levels in the cartridges. As ink is used, the solid color changes to a faded color. Figure 3: Left (tri-color) cartridge almost full - right cartridge emptyc00235259.gif Figure 4: Both left and right cartridges almost fullc00235260.gif
Feb 22, 2011 | HP Deskjet 6940 InkJet Printer
The green light and orange light in my hp9300 continue flash
Try this. 1 Turn on the power 2 Press and hold down the power button and press the Resume (middle) button 4 times 3 Release the Power Button. 4 Your Printer will print a diagnostic page
Good Luck
Troppo
Dec 15, 2010 | HP DeskJet 9300 InkJet Printer
HP deskjet 6940 has been installed. I see it in printers and it says ready but nothing will print to it. On the front of the printer there is a blinking orange arrow. What does that mean?
hello, have you tried pressing the orange button to see if machine will continue and pick up paper and print, also are there any other lights that come on, you might want to take paper out, and turn it around, and install back in. and try again. you might also want to change one ink cartridge at a time to see if that also might be the problem
Oct 01, 2010 | HP Deskjet 6940 InkJet Printer
HP Deskjet printer 6940 clearly prints only top half of a page. The lower half fades and some lines fade completely. Many thanks for your help!
This problem is mainly due to driver corruption
1. Reinstall the driver or scan for viruses and remove it.
2. Remove all temp files from the drive.
3. Try removing corruption in OS or reload OS.
4. Try connecting to another system and take print out.
5. Chipset on the printer may be having problem, get it serviced.
Sep 05, 2010 | HP Deskjet 6940 InkJet Printer
Is a HP Inkjet Print Cartridge 94 compatible witha Hp Deskjet 6940
Not according to the HP site.
It shows 96, 97, 99, and 100.
Go to: HP DeskJet 6940 Supplies
Thanks for using Fixya.
Oct 28, 2009 | HP Deskjet 6940 InkJet Printer
Orange button continuously flashes on HP Deskjet 6940 printer and printer will not print.
it is problem ink cartridge or paper miss feed please chack it and solve your problem
thanks
Tareq
Jul 31, 2009 | HP Hewlett Packard Deskjet 6940 InkJet...
HP Deskjet 6980 InkJet Photo Printer Logo
467 people viewed this question
Seeker5211
Seeker5211
