Question about Toshiba 36A50 36" TV
Screen shrinks screen is reduced to 4" vertical in the middle & backround is black. sound & reception fine.
  • jchambers770 Mar 20, 2009
    started with lines at bottom now only have pitchure in center of screen
  • 125 Answers
Vertical section is failing probably a bad ic or open resistor
Posted on Mar 02, 2009
Screen went black with a vertical rainbow line down the middle
Failue of the vertical section, could be the drive, the power to the section or even some discrete componets. Unless you are familiar with electronics , get some help to ceck out on these circuits, could not be major but to get themain culprit will require good probing.
Jun 29, 2010 | Panasonic PT-56TW53 56" Rear Projection...
27'' lxi reduced picture
This is a problem with the vertical circuit and can be as simple as poor solder connections within that circuit or defective parts. If you have no experience with soldering or TVs, this should go to a service shop. Expect a parts cost in the $30-$40 range for and IC +/or capacitors. If you'd like to attempt this yourself, please supply the exact make and model so I can post the parts required along with additional instructions. Please note that TVs contain potentially dangerous high voltages even when unplugged.
Thanks,
Dan
Mar 15, 2010 | Televison & Video
Screen shrinks down to a narrow band of light in
You have bad grounds on the vertical IC. The grounds will need resoldering and check for weak caps near the ic.....they will overheat the ic...creating the bad grounds. Solder will expand and contract with heat and cooling of a tv. HMMMM you could also have a cold solder elsewhere on the board. Search and you shall find.
Aug 16, 2009 | Televison & Video
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
The shrinked screen with two white vertical line in the middle
B+ line going hi.
probably bad capacitor on hot's collector.
could also be leaky dual diode.
if non of above, look for swollen cap on main board.
Jul 12, 2008 | LG Studioworks 700S 17" CRT Monitor
1995 Mitsubishi 40" Television - Worth Repairing?
there are bad solder connections on the vertical deflection IC resolder them and you will be fine
Mar 13, 2008 | Mitsubishi CS-40503 TV
Showing black screen with a blue line
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Feb 20, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Picture/image problem
Bad solder connection in the horizontal pincussion circuit.have someone resolder.God luck.4tune
Jan 09, 2008 | Televison & Video
Toshiba 36A50 36" TV Logo
101 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
