Question about LG Refrigerators
Just received new fridge today can not clear th
Just received new LG French door bottom frezzer fridge today can not clear th "OFF" display on the programmer to set new temperatures
Try unplugging for 2 minutes
Posted on Mar 02, 2009
I have a ffa90 futre fridge & bottom frezzer. the fridge is frezzing the food in the door & in the fridge. have tryed water in botles & they get ice on it .in the door the food frezzers so
Find where the supply air is coming into the fridge part. It comes from the freezer and could easily be supplying -18 air direct to the door. This would give you a 2 in the fridge but anything in the direct air path could freeze.
Sep 07, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
.i have a side by
Hello, Thank You for using FixYa. I will be helping you today.Yes sounds like the drain tube frozen or blocked.Remove the back cover in the freezer and the drain hole is in the center bottom is it covered with ice? You can use hot water to thaw it or a hair dryer. Im sure its just frozen and be careful not to poke the aluminum evaporator it sometimes takes a little while to get the drain all clear.You will see and hear it drain when its clear.
Thank You and please rate my answer if it was helpful..
Jun 13, 2011 | Maytag Refrigerators
Not working, ER and CO in spots for temp. French
ER CO is an indication of a communication error between the display board and the main board. Has this unit had a board replaced recently? If so, one of the multi pin plugs may have not gotten connected firmly, or an incorrect board may have been installed. The problem has nothing to do with the dust.
Feb 28, 2011 | LG LFX25960ST Stainless Steel French Door...
My fridge is really quite and today i came home and it sounds like a motor is humming or grinding!! when i open the fridge doors the noise goes away?
if there is no problem in the functioning of this fridge then the noise isn't a problem. but still i would advise you to have this fridge checked out by your local repairman.
Jun 11, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
Jun 26, 2009 | LG LFC20740ST Stainless Steel
My freezer section of an LG frech door is not getting cold enough.
you would have to take the back wall of the freezer of (after it has been running a while) see how much of the evaporator is frosted up if none freon leak or bad compressor if just a little on top then a restriction. if you open it and the whole top above the evap is a huge chunk of ice i would try a dryer filter(its part of the sealed system)
Feb 07, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerators Logo
66 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
