Question about Kenwood Excelon KAC-X521 Car Audio Amplifier
Wiring problem for my Kicker ZX450.2 amp
One channel of my new amp doesnt seem to be working..
Temporarly im running both subs off 1 channel and now my subs and toggle switch dont work! help
    Problem Solver:
  • 18 Answers
Wireing an amp can be tough it starts from the e.q.the e.q. must have a sub out.
Posted on Mar 02, 2009
What is the best way to wire two kicker comp r 12' s to a two channel amp for max bass?
First, you need to know whether you have the 2 ohm DVC subs or 4 ohm DVC subs. Second, you need to know the minimum impedance the amp can handle (most are 2 ohm, some are less). Putting two voice coils in parallel will cut the total impedance in half (e.g. 2x 4 ohm voice coils in parallel = 2 ohms total). Putting subs in parallel will also cut the impedance in half.
At one end of the spectrum, you could put the 2 ohms DVCs in parallel, then parallel the two subs, and bridge the 2 channels of the amp. That would put 0.5 ohms impedance on the 1 bridge amp channel. If the amp can do 0.5 ohms x 1ch, do it. Otherwise, you may have to run the subs on separate channels.
Oct 23, 2015 | Kicker Car Audio & Video
2 kicker cvr 12's in prewired kicker box with 1 wire terminal, kicker cx1200.1 amp. Whats the best way to wire this combo?
Well you really can't run both speakers on one term. because you will over heat the amp , unless your amp is rated at twice the capability of your subs , Then if so , Try positive to one sub , then neg. to the other sub , then bridge the remaining positive to the remaining negative terminal , But it is really best to get a two channel amp for your subs !!!
Sep 23, 2013 | Kicker Comp CVR 12 x 12 Car Subwoofer
My kicker dx 500.1 and my xpliod tens worked for all of ten seconds before the protect light went red then green keeps doing that
You are running more then 1 speaker on a 1 channel amp. You need to verify how many ohms your subs are, and what ohm you are wiring your subs to run at. Your amp is only capable of running at 2 ohms.
Here is a link to figure out how to wire them correctly.
http://www.crutchfield.com/S-FKw5viheGLo/learn/learningcenter/car/amplifiers/sub_amp_guide.html
Here is a link to your amplifiers specifications.
http://www.kicker.com/dx_amplifiers
Jun 06, 2011 | Kicker Car Audio & Video
I want a reliable system.
if you bought that equipment today then your answer is yes your amp will power the subs but if i was you and you want more bass I would go with a two channel amp or even a mono block amp that will be 1 ohm stable and if you decide to do that you might want to get subs that are dual 4 ohm voice coils and run them in series that will get you 1 ohm of resistance
May 19, 2010 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
Subwoofer buldging out problem
When speakers are wired in the wrong way the will do the "pushing out" you're describing. Basically the polarities have been reversed and if kept like this over a period of time will blow the speaker. Best thing to do is to disconnect the power by the negative on the amp and take out the fuse from the power supply. Check the wires running from the amp to the subs, negative to negative and positive to positive. I know it sounds basic but many people do mix it up! I would also check to see what channels the subs have been wired into?
Best way is to have one sub from channel 1 and the other sub from channel 2 for example. Or if its a bridged 4 channel amp, have 1 sub running from channel 1&2, and the second sub running from channel 3&4 still making sure of the polarities. Again this all depending what kind of amp and sub you have.
For example;
A 4 channel (bridged) 1000W amp. 250W max per channel or 500W per 2 channels! So if you have 2 500W subs, by connecting one to a single channel will decrease subs ability due to the lack of power supplied. However by combining 2 channels you optimize the output!
Once you know all your wiring from your amp to subs are ok/good connections/good wires etc you shouldnt have to "wiggle the wires" to get it to work as this is just a bad connection. Also ensure that no 2 wires are touching. Make sure that the master volume on the amp is turned down. You dont need this to be on loud at all, in fact far from it or you'll risk damaging both the amp and subs!
Hope this helps!
May 27, 2009 | Car Audio & Video
2 car subwoofers, one doesnt play
Short in amp ? try swiching wire's to speaker's around . if other speaker then work's , speaker's are both fine . if not , then short in amp , or blown channel in amp . get new one or find someone who know's more than i do about amp's
May 24, 2009 | Kicker CVR12 Car Subwoofer
Car audio
Most likely the RCA's are running from the sub out on the deck to the amp. You need to run two sets of RCA's for a 4 channel amp. One for the sub out and one to the front or rear channel.
Hope this helps.
May 12, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Amp is on but wont work...please help!!
Hello lillj2323,
OK, you say that the amp won't get your RF Punch's to pound. You do not say if you get any output at all. So let's start from the beginning.
The KAC-X542 is a multichannel amp with 2 sets of stereo outputs, 1 set of stereo outputs and 1 bridged connection for sub(s), or 2 bridged connections for sub(s).
Make sure that both 30A fuses just to the left of the power connections are good.
Check that the "ID number" is set to "0". Make sure that you have RCA inputs to both channels A and B (leftmost pairs of jacks). Your subs should be connected to the 1st (+) and 3rd (-) of each set of output terminals.
Make sure that there are no broken off plugs or pins in the jack marked "H/U Terminal" or either of the 2 jacks marked "remote".
Check that the amp is set up for 2-channel bridged. The 6 switches below the filter controls and the filter pots should initially be set:
1 - Middle position (off)
2 - Up position (on)
3 - Down position (off)
4 - Up position (mono)
5 - Down position (off)
6 - Up position (mono)
The pots should be set approximately:
LPF - minimum
HPF - maximum
Input Sensitivity - match your head unit - probably between 1 - 3
HPF - maximum
After you get the speakers working, the LPF, HPF and Input Sensitivity can be tweaked for best sound and lowest distortion.
Hope this helps.
Apr 17, 2009 | Kenwood eXcelon KAC-X542 Car Audio...
The amp is only putting out on 1 channel
I do believe this is caused by one of your amp fuses. Depending on which + on the amp is being used. That channel has a blown fuse. have you tried running + and -, + and - to both channels to see if both subs worked? If one sub doesn't then it's a blown fuse or scarred fuse and needs to be changed.
Feb 10, 2009 | Kenwood Excelon KAC-X521 Car Audio...
Wiring my 2 L7 with a kicker 1000times1
Run the subs in series then bridge the amp. So run the normal + to - to the one sub then hook up a spare wire (not connected to the amp) to the same + and - connections. Then run the spare wire to the + and - of the other sub. This will tie the 2 together so you can bridge the ampfor more power instead of using 2 seperate channels.
Feb 01, 2009 | Kicker 02S10L74 Car Subwoofer
Kenwood Excelon KAC-X521 Car Audio Amplifier Logo
62 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
