Question about Casio Exilim EX-Z750 Digital Camera
Camera Memory Card Capacity
I have a Casio 'EX-Z750 camera and just purchased a 4GB and an 8 GB memory card. Neither will work in my camera. Are they not compatible and what is the largest size memory card I can use?
  • 423 Answers
Hi there, and welcome to FixYa.
First, make sure your cards are either, SD or MMC. Any other type won't work.
If they are SD and/or MMC cards, then the reason the cards aren't working is because they have to be formatted in the camera BEFORE you use them. Use the camera to format the cards, don't use your pc or a card reader.
The manufacturer says to use a 2gb card, but that doesn't mean you can't try a higher one. The only thing is that maybe it won't format the card right. Or, it may slow down the processing speed. It won't hurt the camera any.
Have fun with your camera. If you have any further questions, leave me a comment, and don't forget to rate my solution.
Rob
Posted on Mar 02, 2009
The casio ex-z750 does not support SD HC cards. (Almost) Every card that is 4 GB or higher is an SD HC card. This is why the cards don't work.
Posted on Mar 19, 2009
My Casio ex-z75o is only taking 7 photos before it says memory full i have tried different memory card but no change
Delete the photos off the internal memory and remove the battery. this will reset it the factory setting and that should clear it up
May 03, 2014 | Casio Exilim EX-Z750 Digital Camera
I lost my memory card for my casio ex-z750 7.2 mega
The EX-Z750 uses SD cards up to 2GB in size. These cards should be available at just about any department, electronics, or office-supply store.
Oct 01, 2012 | Cameras
What kind of memory card is used in casio ex-z750 7.2
Oct 01, 2012 | Casio Exilim EX-Z750 Digital Camera
My camera gets easily full though i've just taken only one or two pictures. What should i do? Please help me solve this problem. I badly need my camera now as I am documenting for my thesis. Thanks much.
Sounds like you may not have a SD memory card in your camera (or have been using a 4GB SDHC card), and your images are being saved to the camera's very limited "built-in" memory. What size SD memory card are you using. If there is none (or if you're using a 4GB SDHC), recommend purchasing a standard SD card no larger than 2GB files size for your model camera (think of it as the camera's reusable film).
Note that 4GB and higher SDHC cards will not work with your camera as it was manufactured before SDHC format came out (this also could be causing the camera to default to built-in memory). Again, the maximum SD card size that your camera can use is 2GB. These can still be purchased, and are relatively inexpensive on Amazon.
Mar 24, 2011 | Casio Exilim EX-Z750 Digital Camera
I have a Casio Exilim ex-z40 camera and tried to install a 4 GB memory card. The camera says "Card Error". Will this camera take a 4 GB card or should I stick with the 2 GB I have in it now?
The EX-Z40 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot it is electronically incompatible and will not work. You need to stick with SD cards, 2GB and smaller.
Feb 13, 2011 | Casio Cameras
How big of an SD card can I use with my Casio EX-Z750 Camera? I'd like to use a 4 GB or 8 GB but was warned they may not work. Can't find this info on the Casio site, and don't want to waste money on...
The Z750 uses SD cards and is limited to 2GB cards. 4GB and up cards are SDHC (Secure Digital High Capacity) cards and do not work in devices designed for SD cards. This is a hardware issue and cannot be upgraded in firmware.
SD cards will work in SDHC devices, but not the other way around.
Jan 19, 2010 | Casio Exilim EX-Z750 Digital Camera
I HAVE A CASIO EX-Z50 DIGITAL CAMERA, WHICH I HAVE HAD A WHILE AND I HAVE BROUGHT A 4GB MEMORY CARD, THE CAMERA DOES NOT SEEM TO LIKE THIS. PLEASE COULD YOU TELL ME WHAT IS THE MAXIMUM MEMORY CARD THIS...
yes this camera support 4 GB memory card ..SD memory cards and multimedia cards only can be used to expand camera memory.This model does not support use of CF cards, the IBM Microdrive, or smart media.
Aug 21, 2009 | Cameras
Trying to insert 4 gb memory card
That is correct. The camera was designed to work with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Jul 13, 2009 | Casio Exilim EX-Z40 Digital Camera
Casio Exilim EX-Z750 Digital Camera Logo
210 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
