Sony DVP-NC600 Multi-disc DVD Player
Problem for Sony DVP-NC600 Multi-disc DVD Player
Sony DVP-NC600 Multi-disc DVD Player No Disc Error
By mrbohm on Mar 02, 2009
My Sony DVP-NC600 Multi-disc DVD Player shows a No Disc error  whenever I put a disc in. Sometimes it will grab the disc and  spin it, other times it will not even pick it up. I removed the  cover and used optical cleaner on the lens and cleaned through  out unit. Still problem persists.   Machine is about 8-9 years old (good run...I know, but would  like to use as a second player) is there something that can be  done to remedy? Thank you.
Comments:
Mar 02, 2009
- Thanks for your time, I'll give it a try!
Solution #1
posted on Mar 02, 2009
Not Rated)
xSonyTech
Rank: Master
Rating: 87%, 28 votes
The only other thing I can suggest, having repaired many Sony CD/DVD players, is to get a can of compressed air and try to blow any dust out from the laser assembly. Since you've already cleaned the lens (the most common problem), you also might have dust down inside the assembly. Try blowing with the air nozzle down inside, around the gap between the lens and the cover surrounding it. Do it from at least a couple of inches away, if the air is too powerful you can damage the wiring inside the assembly.
If this fails to correct the problem, your laser output may have diminished over time and the only repair is to install a new laser assembly. The cost of this part will most likely not be worth it to you since the unit is quite old now.
Was this helpful?
Yes
No
Popular Solutions for Sony DVP-NC600 Multi-disc DVD
Questions and Unsolved Problems for Sony DVP-NC600 Multi-disc DVD
Do you recommend Sony DVP-NC600 Multi-disc DVD Player?
Answer
Answer
I have a sony DVP-nc600. I was playing it with all five discs and it was on shuffle. It was... (More)
Answer
Mainly with CDs (but will on DVDs) - it just plays and then (I think hits a read error) just gives... (More)
Answer
kiss my arss this siisue being posted twice ton & 3 times is not help anyone I have the 5... (More)
Answer
DVD Tray continues to spin and I receive the error code: E 27 00
Describe your DVD Players problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Player Experts
Top TV Repairmen
in , DE
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
