Question about NAD C320 2-Channel Amplifier
2002 Mercedes C320 wagon / fuse for cigarette lighter
Which fuse is it? Where is it?
Just did this on my 2002 C320. The blue 15 amp fuse is located in the front fuse box under the hood. It is either #47 or 48. If you already opened the driver-side fuse box, see if the paper fuse map is still there. If it is, find the fuse to be sure. Replacement is very easy, but there is a fuse puller tool in the spare tire well where your kit of replacement fuses should be. if you are in luck and you have a replacement, use the puller tool and replace the fuse.
Posted on Sep 08, 2009
    Problem Solver:
  • 6 Answers
Very simple, The lighter fuse is located in the driver (FUSE) are. Located as you open the door there will be a (Panel) the fastest way to fix this is to PULL all fuses one by one and find the burnt fuse and replace it.
Posted on Sep 07, 2009
SOURCE:
2002 c320 radio and cagarite lighter do not work.
Had the same issue on 2002 c320 . look at the fuse chart ,find out the fuse # that operate the radio and the cigarette lighter , you have three fuse boxes, engine compartment, driver left knee and trunk on left .find the fuse b compairing the char to the box , replace the fuse . DONE
Jul 01, 2014 | 2001 Mercedes-Benz C-Class
Replace cigarette fuse in 2005 mercedes 500
Pull cover off left end of dash to find the fuse card and replace with same rated fuse.also check lighter socket that their are no objects fallen into it.
Apr 22, 2014 | 2005 Mercedes-Benz E-Class
2000 mercedes E280 where is the fuse for the cigarette lighter
Check front SAM f54a (15A), it is located in the driver side rear area of the engine compartment.
Mar 25, 2012 | 2000 Mercedes-Benz E-Class
Lighter does not work in Mercedes C320 ...pleas advice...Mike
There should be a separate fuse for the lighter 10-20 amps?
Oct 12, 2010 | NAD C320 2-Channel Amplifier
Where is the fuse for cigarette lighter. fuse
Hi! The cigarette fuse is somehow interconnected with the radio fuse. If no luck, then i believe that the cigarette lighter needs to be replaced. Hope this helps and have a good one!
Apr 20, 2010 | 2003 Mercedes-Benz C-Class
Radio and cigarette lighter not working 1991 mercedes 190e
Spin or replace the fuse as the old aluminum fuses build up corrosion and dont work, or work on and off.
If its an after market radio check by removing unit and checking for fuses in line.
Jul 17, 2009 | 1991 Mercedes-Benz 190
1995 camry wagon cigarette lighter not working
start with a test light and check for power at the center of the cigarette lighter socket. If power is good, then check for ground at side of lighter socket.
If no power, run wire from power wire of lighter to power wire of stereo, thus tapping the power directly and bothering to trace out where the open int he circuit may be.
Jan 25, 2009 | 1995 Toyota Camry
NAD C320 2-Channel Amplifier Logo
1,411 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
cheekygr1n
Level 1 Expert
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
