Question about Brother DCP-7020 All-In-One Laser Printer
Paper jam around the back of printer - can't seem to find a release and paper is tearing with stiff tension
  • don_kawaja Mar 02, 2009
    Thanks - the rear access door was v. hard to open - especially as I didn't want to break any of the flimsy (sorry) plastic. Finally jiggled it enought to do the job w/o damage - thanks again!
    Don
    Sergeant:
    Novelist:
  • 277 Answers
On the back of the printer there is a access door justy open that door its removable and then slightly pull the paper it will easily come out.
Posted on Mar 02, 2009
Clear a paper jam on 3330
When you say "release it from around the roller", do you mean that the page looks like it is wrapped around the roller? If so then the fuser will possibly need replaced. Depending on how skilled you are you could try removing the fuser and disassembling it to remove the paper but it may not be possible. if you decide to try be careful not to tear the "roller". It is actually a fixing film, a thin mylar type product with a nonstick surface. It is easy to damage it and then you would have to replace the fuser for sure.
Jan 04, 2013 | HP LaserJet 3330 All-In-One Printer
Paper jam
Hi. This could be sendor is failing or there is a jammed paper on you printer.
How to removed jammed paper
1.Unplug all cables (USB and power)
2.Turn around the printer
3.In the back there should be a small door that on my printer (SCX-4300) flips upside.
4.Look for any jammed paper.
5.Pull out the jammed paper.
Here's how to fix the sensor
Unplug everything from the back and then remove the four screws from the back panel. Pull the panel out but watch that the on/off switch doesn't hang the cover up.Once off, I removed the screw from the mount holding the right end of the sensor stick while holding the mount in place with my finger. When the screw is out, lift the mount up and carefully slide it off of the stick. Carefully rotate the spring, topside away until the left side of the spring catches the sensor piece. Now rotate the other end of the spring once more around the stick and while holding it at the top of the stick (12 o'clock) slide the mount back on. With the mount in place, release the spring and it will come to rest on the mount. Refasten the mount and check for light tension on the sensor. If it pushes forward when you release it, you're good to go. Refasten the back panel, attach all wires and enjoy.
Have a good one!
Jul 28, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Paper jam
take out cartridge and force paper to take out sometimes it is needed to tear paper to take it off but no problem, main sensitive for this type of printers is cartridge, also find if any "jam lock" is presented to ypur printer and unlock.
Aug 01, 2009 | Brother HL-2070N Laser Printer
How can fix the jammed paper situation?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-17
Jul 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper jammed in my 2070N printer & I don't know how to remove it
That machine doesn't have a release lever, you need to pull the paper out, as straight as possible trying not to tear it. There probably is a problem with your fuser, and it will need to be replaced. Even getting the paper out, it will probably jam again on the next print.
Jul 22, 2009 | Brother HL-2070N Printer
Brother 2920 Fax Machine keeps jamming every few pages
Please try this and let me know how it goes
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother IntelliFAX 2920 Plain Paper Laser...
My paper has been jamming when fed from the back. I found a foam piece that has come from somewhere in my machine. the piece is about eight inches long and seems that it might have had an effect on the...
try this
alternative :
Jun 08, 2009 | Canon Pixma MP800 All-In-One InkJet...
Paper jam
Solution one: Clear the jam from the back of the All-in-One Follow these steps to clear a paper jam from the back of the product. Step one: Remove any loose paper Remove any loose paper from the input tray. CAUTION: Do not remove jammed paper at this stage. Step two: Clear the jam from the back CAUTION: Always clear paper jams through the back door if possible. To avoid tearing the paper and damaging the print mechanism, pull paper from the product slowly and gently. Avoid touching the internal components of the product.
  1. Disconnect the power cord from the back of the product.
  2. Remove the rear door. Push in the two release tabs, and then pull the door toward you.
Feb 01, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Paper Jam
on the back release the cover and pull it out. you cant release the tension.
Jan 27, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Paper jam
hey, give this a shot
alternative :
Oct 19, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
Brother DCP-7020 All-In-One Laser Printer Logo
320 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
