Question about RCA RCU300WBL Remote Control
Have admiral tv with rca systemlink 3 remote.
I put in the code 1-7-3 following computer instructions and can't get tv to respond to rca remote. We were given this tv and remote from a relative and they used them together. What else do we do to get this to work?
  • 20 Answers
Re: need codes for rca remote Systemlink 3 for 22729 tv
Katina, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://www.remotecodelist.com/remotes/rca/rca_systemlink_prog.html
RCA universal remote code lists RCU Series Systemlink series direcTutor
Electro help RCA SYSTEMLINK 3 UNIVERSAL REMOTE TV SETUP CODE LIST SETUP...
Aug 19, 2016 | RCA Televison & Video
I need the tv codes for a systemlink 3 rca universal remote
There are no Coby TV codes in my Systemlink 3 instructions. You might try code search to find something that will work
Nov 13, 2012 | RCA RCU300 Remote Control
I have a universal remote systemlink 3 RCA. I need the code to program it. I have Goldstar TV. Thanks.
1.Use one of the following three digit codes for your TV set:
004, 005, 006, 012, 019, 056, 057, 058, 155, 156, 171, or 1722. Manually turn on the TV set.
3. Press and hold the CODE SEARCH button until the indicator light is lit. Then release the CODE SEARCH button. (The indicator light is located above the TV button).
4. Press and release the TV button. (The indicator light will blink and then remain lit).
5. Enter a three digit code found at step 1 using the Number Buttons.(After the code is entered the indicator light will turn off).
6. Aim the remote at your TV. set and press the OFF/ON button. If your TV. set turns off, then proceed to step 7. Otherwise, repeat step 3 to 5 using the next code on the list. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
7. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
8. If none of the codes work, you will want to use the following to go through the codes manually (this will take some time):
Code Search for the right TV code on a Universal Remote (systemlink 3 RCA)
1. Turn on the TV.
2. Press and hold the CODE SEARCH button until the indicator light lights. Then release the CODE SEARCH button.
3. Press and release TV button. The indicator light will blink once.
4. Repeatdly press and release the OFF/ON button until the TV turns off. It may be necessary to press the OFF/ON button up to 200 times before the TV turns off.
5. When the TV turns off, press the ENTER button. Now the Device is programmed for the TV set.
Aug 05, 2011 | RCA 3-dev Universal Remote Remote Control
WHATS THE CODE FOR RCA TV ..I HAVE A ONE FOR ALL UNIVERSAL REMOTE NEED THE CODES TO PROGRAM MY RCA TV
You received a list of ALL Codes with your universal.
I got this off the internet. But I do not know what type of universal you bought. You didn't mention it.
Good Luck.
Here is the link if you need it. :0)
http://www.google.com/search?q=universal+code+for+rca+tv&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7&rlz=1I7GGLL_en
rca
Nov 07, 2009 | Universal Remote Control P000203220-1...
Need code # for rca tv
If your remote control has a search button, this is how you do it-------- User submitted information for the SystemLink 3: To clear things up and make it simple, here is how to program the RCA Systemlink 3 remote:
****WITH DEVICE TURNED ON****
  1. Press and hold the "Code Search" button until the LED lights, then release. LED will stay light.
  2. Press and release the device key to be programmed. LED will go off when button is pressed and back on when released. LED remains on.
  3. Press and release the remote On/Off (power) button as many times as required to turn your device OFF.
  4. When device turns OFF, press and release the ENTER button.
Test remote on device, if ALL functions do not work, repeat above procedure.
***IMPORTANT NOTE*** Count how many times you press the On/Off button. If ALL funtions do not work and you need to repeat, you don't want to stop at the same non-working code. For instance, if it takes 23 times to turn your device off and after testing, the remote does not control all functions, repeat steps 1-3 BUT when the device turns off at the 23rd time, turn it back on using the power button ON THE ACTUAL DEVICE then continue with step 3 and 4 from above.
Nov 19, 2008 | RCA 3-Device Universal Remote with...
Universal remote codes
I found the following web site which lists the codes for the RCA SystemLink 4 RCU400C universal remote.  It's http://www.thompsontv.com/rcarc.html.
Mar 08, 2008 | RCA Universal Remote Control
SYSTEMLINK 3 RCA UNIVERSAL REMOTE CODE 4 A MAGNOVOX TV
MY TV IS SANKEY AND I CAN`T FOUND THE CODE IN THE LIST OF MY SYSTEMLINK3 RCA, Please i need help! Thank`s
Nov 06, 2007 | RCA RCU300WBL Remote Control
RCA RCU300WBL Remote Control Logo
307 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
