Its the faulty cable in your printer .it will not solve by resetting the cable in the printer needs replacing only that will solve the issue completely.common problem faced by many users.
plz rate
Hi!
Is it printing the documents correctly? Try cleaning the printing queue from control panel-> printer and faxes-> double click on printer and delete all files in the queue.
Also, try restarting the printer spoooler.
You can restart the printer spooler by---
Go to Start > Run. Type services.msc and when the list is presented, click on the list of items, type the letter p to jump to the services starting with P. "Print Spooler" should be one of them. Double click it. Set the startup type to "Automatic" and restart it.
What program are you printing from?
The problem is most likely caused by the computer or the program your using. Try printing your email from another program, if your reading email from internet browser, then try another browser.
Do other documents print properly? Word - doc - etc?
One possible solution is to completely uninstall the printer from your computer, delete it from printers and faxes and uninstall the software from add and remove programs -Start -> control panel -> uninstall programs or add or remove programs.
Ones its fully removed, download and install the latest drivers.
they are available here on epson page
If the problem is with all documents and programs.
check that your not runing out of ink, Perform head cleaning on the printer.
Press the setup button on the printer, select maintenance from the options and press ok.
Perform a Head cleaning, and head alingment.
If the problem is only with your email program or with browser, try another browser or another email program.
Solution works only part time??
How do I restart the spooler?
Before I try the more radical process you describe, I would like to try out over a period of time the solutions that I have received to date. I think they may have solved my partlal page email printing problem.
Thanks,
Rolund De Hoog
