Question about Buffalo Technology (HD-HB250U2) 250 GB Hard Drive
System freezes when I connect my external hard drive.
I have used my Buffalo HD-HC250 external hard drive for a year with no problems. Now when I turn it on my computer system freezes. It wont do anything until I disconnect the hard drive or turn it off. When I turn it off my system immediately starts to work again. I downloaded a driver detective that says the driver is up to date. Any suggestions?
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
I have had my current Buffalo MiniStation Plus HD-PNTU3 for almost about a year now without an issue or problem but recently it refuses to open on another computer while it works fine on my own. I am
The device probably can with a Buffalo utility/driver disk. The other computer will need these drivers to recognize the device. If you lost the driver disk, you can download them here: http://www.buffalotech.com/support-and-downloads
May 31, 2013 | Buffalo Technology Buffalo MiniStation...
Computer wont recognise external hdd
Follow these steps:
1. right click on My Computer
2.Click on manage
3.Click Disc Management
There you can see External hd (you can chose to activate or change drive letters and that will do the job)
Mar 29, 2013 | Buffalo Technology DriveStation HD-HC500U2...
When I turn Buffalo 1TB drivestation on for first time and go to My Computer, it will not open window and freezes computer.
1st of all try it in another PC, and see if it does then same. Then we can establish if it's the drive station or the PC.
Unified IT Systems Ltd
Jul 21, 2012 | Buffalo Technology 1TB DriveStation...
My external hard drive started to make rRrrrrRrRRrRrrrrrr sound and now my computer cannot detect it and no icon appears, it has been working for months and now it wont work. if i click the hard drive or...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Jul 10, 2011 | Buffalo Technology Buffalo DriveStation...
My external hard drive (buffalo HD-PE320U2) is not working. when I plug it on the computer it says "windows does not recognize it" or it has malfunction. what will I do with it?please help I...
First uninstall the software,make sure the external hard drive is not connected to the PC and use your install disk to reinstall the software.You might all so try system restore.Thank you for choosing FixYa.com.
May 18, 2011 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
My buffalo external hard disk can not read since yesterday, I/O device error. previoous was working fine. Do not know why? my Buffalo external hard disk model :HD-PX320U2
it is a PNP (PlugNplay) device. Try using a different cable to connect to your pc. Should the problem remain, hook it up to a different computer and if it doesn't see the drive, it will be an electronic circuit failure inside the box. The data is still on the hhd but you will have to obtain a new circuit to bring the hhd back online for use.
Apr 13, 2011 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
1tb usb hard drive with "file system damage"
try replacing all the leads that attach the hard drive to computer
Jul 25, 2010 | Buffalo Technology 1TB DriveStation...
When I enable TurboUSB, it turns off my ext hd
yes..that is predictable..most externals can not take the boost without a firmware update. check the buffalo site for a driver
Dec 05, 2009 | Buffalo Technology 1TB DriveStation...
Can't access Buffalo HD-HB250U2-WR 250gb Ext. Hard
This might be problem with the cable. Try using another cable.
Sep 02, 2009 | Buffalo Technology (HD-HB250U2) 250 GB...
Buffalo Technology (HD-HB250U2) 250 GB Hard Drive Logo
239 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
