Question about Whirlpool Home
Bathtub water jets . is there a way to plug / close them
Bad smell  and  slime .i would rather not have them
  • 3 Answers
Try using dish washer tablets in water they clean out tubes 3/4
Posted on Mar 04, 2009
What cleaner gets the bad smell and crud out of jacuzzi jets?
Here is a link to a site that sells jetted tub cleaners.
Bath Parts Plus Bath Pump Spa Part Spa Accessories Powered by Network...
Any of these cleaners work very well at removing the smell from a jetted tub and the bacteria in the pipes as well.
Rod
US Parts Center
Mar 15, 2014 | Jacuzzi Home
How do I get bad smell and crud out of jacuzzi jets
If you are experiencing a "smell" coming out of the water when you use the tub then you should use one of the products that are made for cleaning jetted tubs pipes.
Here is a link to a site that carries those items. These will get rid of the nasty smell and flecks of bacteria when you use the tub too.
Rod
US Parts Center
Mar 15, 2014 | Home
LG dishwasher LDS 5811 WW smells really bad has a slime film everywhere it was coated all over the upper arm and lower spray arm- dishes are not getting clean- and it smells so bad- any ideas?
it sounds like the problem is your water. go to www.dishwasherfilter.com and check out the dishwasher filtration system. it will solve your problem and works amazing. it is guaranteed or your money back.
May 14, 2013 | Dishwashers
SMELL COMING FROM LARDER FRIDGE,FOUND THE PROBLEM AT BACK WHITE TRAY ON TOP OF MOTOR A BUILD UP OF SLIME , FINDING A PROBLEM TO CLEAN TRAY,
This is the defrost water that collects on the collection tray - white tray on top of motor. Normally over a period of time the water evaporates off but if there is collection of dirt it can smell. So you need to PULL out the tray - use a screw driver to release the lock and the tray will come out which can be cleaned using a water jet and detergent.
Apr 06, 2011 | Refrigerators
Makes noise but jets do not work
Is intake clogged? sounds like impeller has come loose from pump if not.Take a garden hose and feed water back from a jet(closing/plugging others) to see if it flows back out intake checking for obstuctions. Are jets all the way open and water level well above intake?
Oct 04, 2010 | American Standard Cambridge 5' Americast...
Jacuzzi jets smell like rotten eggs when turned on.
Need to run some cleaner through jets to clean out old water and mildew.
May 09, 2010 | Home
Water coming out of adjustable air vent behind wall of tub
one or more of the jets are turned off. i would suspect someone is plugging the jets off which causes water to go backwards in the system and the water goes out the air controls. solution: check the jets to make sure the jet faces are turned on and/or tell someone to quit plugging off the jets when they are in the tub.
Mar 03, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I have an Eljer jet bathtub with a smell to the water when we bat
What you smell is algae forming in the pipes. If you have small black particles in the tub when running the jets, it is algae. Fill the tub with hot water, add 2 teaspoons of cascade dish soap and 1/2 cup bleach. run the tub for 15 minutes and drain. fill tub with cold water, run for 15 minutes and drain, tub is now ready to use. repeat as necessary.
Aug 02, 2009 | Home
Smell coming from jacuzzi whirpool tub
the jet covers normally unscrew counter clock wise .As far as the smell goes it could be clumps of old hair after time the old hair usually causes a pretty bad smell.Try snaking the drain.This might help.
Feb 01, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
Indoor jacuzzi bathtub problem
Just add 1/2 cup bleach to a full tub of clean water, turn on the jets.
Grab a small goldfish strainer / net and scoop out the moldy chunks.
Keep cycling the water until most of the chunks are gone.
Drain the rub, refill and add 1/2 cup bleach again, repeating the process.
The problem is caused by water left in the lines after use, and it turns moldy.
After each use...drain the tub completely, then turn on the jets for about 10 seconds. This will purge the lines of any standing water.
Fill the tub with clean water and cycle the jets with bleach once a week to prevent any further problem.
Hope this helps...it worked for me, I had the same problem.
Nov 27, 2008 | Home
Home Logo
321 people viewed this question
Top Whirlpool Home Experts
Donni Steen
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
