Question about Electrical Supplies
Eerie Orange/Red Glow Inside Floodlights (bulbs)
I have just installed the SH-5412 Heath Zenith Motion Sensor Light Control to replace an existing motion sensor flood light. While the sensors seem to work and turn the bulbs on full blast (you can see them get brighter) when they are not in use, there is an orange/red glow in the center of each bulb.
Should I be concerned about this? Is this what is considered the Bulb Saver technology? Will this generate a higher electric bill?
  • Anonymous May 29, 2009
    It's exactly as the previous poster (tmorlock) pointed out. I just had the Heath Zenith Model SH-5525 installed and it works fine, but there is this orange glow in the halogen lamp which seems to be often present. I called the electrician, and he was mystified. It may well be by design, since other people have encountered the same difficulty. At least I hope it is by design
  • 979 Answers
I think this is by design. Look at the instruction manual and it should tell you. This doesn't make sense that they should be on, but they may have a reason for it in their design. Now to the bulb saver technology thought, you are mostly right here. There is a lot of "strain" if you will on the filament when starting it up and it does cause a weakening over time. You will notice that when a bulb goes out, it usually happens right when you turn it on. The same thought here. I suppose in this device, that a constant voltage (low) is better and more efficient than zero voltage to 120 volts. They probably take into account the sensor will be used several times a day thus making the need for this kind of set up even more demanding.
Posted on Mar 04, 2009
Sh5412. The red lite blinks when walking past but the spot liters do not come on. The test was ok
What test did you do? Did the floodlights come on with the sensor switch in the Test position? Did you wait two minutes after turning the circuit on? Is the sensor in the dark? If your answer is yes to those questions, then try the following:
Double check the wiring. Sometimes a wire will come loose if the stranded wire from the fixture is wrapped all the way around a solid house wire. The solution is to gently bend the bare tip of the solid wire in a soft s shape so that the stranded wire does not completely wrap around the solid wire when the wire nut is twisted. (I know that you said the sensor red light is coming on but the additional load of the floodlights' current may not flow if there is a loose connection, very little current needs to flow to operate the sensor.) (The wires should be connected something like this -White from house to white for sensor (and to whites for lights unless this light connection is done internally in the sensor by Heath Zenith), Black from house to sensor, Other colored wire from sensor to lights (again unless this light connection is done internally in the sensor by Heath Zenith)- Also check that the spotlights are not burnt out and that they are tight in the sockets.
http://www.heath-zenith.com/servsup_instvideos.htm
Oct 22, 2014 | Heath Zenith Secure Home Motion Activated...
Need the manuel for setting heath zenith lamp module model no BC-465
i have a question about heath zenith motion sensor light.
i put up two new Heath Zenith Motion Sensor Light Control the i buy from home depot tie into switch leg. When i put in on test it work fine stay on for a few second them off, but when i set up on automatic Time-1min.\ Dual Brite-off \ Lamp Mode-Normal light go off and them come back on for the rest of the nigh long and go off morning time. Any body have this problem?
Jul 06, 2012 | Heath Zenith Secure Home Motion Activated...
Own a #182155 secure home SH-5105-WH-B light stays on all the time.testing it in a dark room with door closed,light can be seen under door,never goes out.any help you can offer would be great!
Switch the Dual Timer selector to OFF.
Wait 1.5 minutes for fixture to recalibrate.
Then check fixture again.
http://heath-zenith.hcents.com/data/manuals/598-1152-05.pdf
Aug 04, 2011 | Heath Zenith Secure Home Motion Activated...
Need to wire motion sensor to light, have three wire(red, black & white), need to know how to hookup wires? my model no. is :-heath zenith sl-5318-bz-a
The black wire goes with the black house supply wire, and the red wire goes with the black wire from the lighting fixture. The white wires all connect together.
Feb 22, 2010 | Heath Zenith SL5316WHB Replacement...
Outdoor sensor won't work
Hi, Remove the cover and check for power. If you have power,replace it.No power, look for a tripped breaker. Good Luck,
Shastalaker7
Nov 14, 2009 | Heath Zenith SL-6106-IV Motion Sensing...
Flood light has faint glow at all time
Sounds like you have the Dual Brite on, the dual brite is low level accent lighting. Check to see if you have this switched on, if so turn it off.
Mar 12, 2009 | Heath Zenith SL-6136-WH Basic Solutions...
Flood lights take a very long time to come on
Insure you are using a standard flood light on motion sensor lights and not a florescent energy efficient flood light as they take longer to reach full brightness as the bulb filiment warms up. They are better suited for constant lighting rather than intermittent purposes such as sensor lights.
Good Luck
Nov 21, 2008 | Heath Zenith Electrical Supplies
Heath Zenith Security Light fixture with motion stopped working.
I am in the middle of a discussion with Heath/Zenith over a closely related and perhaps identical issue. I purchased their 5718 model from Home Depot and based on the fact that their brochure stated that "CFL bulbs are only usable on 270 degree units." I purchased the model 5718 unit (270 degree) and used CFL bulbs. It experienced the same problem others noted.
The technician at Heath/Zenith told me that only DIMMABLE CFL bulbs would work with this unit (even if the DualBrite feature is turned off). Standard CFL bulbs will not work.
Their brochure does not make that clear. Perhaps that is the answer to others' problems.
Nov 12, 2008 | Heath Zenith SL-6136-WH Basic Solutions...
Electrical Supplies Logo
254 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
