Question about Konica Minolta DiALTA Di183F Copier
Di 183 J-- error
Minolta Di 183 showing J-- . Have looked for paper and checked fuser door switch. All is as should be. Could this also be a fuser error?
  • ossie al Mar 02, 2009
    Thanks Tom.
    I removed the exit sensor and cleaned it out. There was alot of fine white dust causing false reading. Thanks for your help I will keep the code list.
    Al
    Problem Solver:
  • 12 Answers
Di 183  J-- error - 715ebf9.jpg7a749f4.jpg good luck!
Posted on Mar 02, 2009
How to clear error code c0f32 problems by minolta Di152
replace the developer and drum , clear counter and run F8
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 24, 2015 | Konica Minolta Bizhub 180 Di 152 152f...
Minolta di350 jam at fuser
IF you can find a fuser. The Di 350 is a legacy Minolta, now Konica Minolta. mite be able to find refurbished unit. If accordion check to make sure the pick fingers are not broken they prevent paper from wrapping around the fuser roller. one mite be broken causing it to hit it.
Dec 10, 2013 | Minolta DiALTA Di350 Laser Printer
(C-0500) error code konica di 470
There is a trouble rest button inside the front door above the fuser unit. There is a small panel with one screw in it, remove the cover and you will see a PCB with two black switch's on it. One is the trouble rest button, have the copier ON and press the trouble rest button and close the door and you are done... If it will not rest, check what you did and make sure it is put back correctly.
May 06, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
Hw do i fix my minolta dialta di 552 for continuous paper jam
Where is it jamming, which draw are you using have you tried different draws or the by pass tray? Does it jam when copying versa printing? Have the draw rollers been cleaned? jamming in the fuser the hot part or under the drum before the fuser?
Mar 09, 2013 | Minolta Office Equipment & Supplies
After a power failure we got the error code C0500 when power was switched on again
Enter in the service mode STOP 0 STOP 0 1 ,press trouble reset,or open close the front door.
Jan 28, 2013 | Minolta DI-2010F Copier
Error code c0520 konica minolta DI 2510
Sir/mam,
First open the right side cover where the image unit is located. Check the two latches that latch the door ensure they are not broken, especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with the copiers on it on the left side of the screen in the middle you will see a small "." When the dot appears touch 3 button. Then the machine will continue to the code screen. Press the Utility button you should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day.
Oct 18, 2012 | Konica Minolta bizhub Office Equipment &...
What is c0120 error
error code C-0120 in konika minolta model no C-450
Feb 03, 2011 | Konica Minolta Minolta DI1610P Printer,...
I have Dialta di 183 . the problem is when i power ON . it will automatcally OFF for a seconds.
Does show any code on the screen like C0500 or something like that try turning it on with the stop button held down to reset the fuser (THE HOT PART) also check make sure the electrical plug is plugged into the machine tight and snug, if not sound like a power supply problem, might want to get a konicaminolta tech to come out a look at it.
Jan 21, 2011 | Minolta DiALTA Di183 Copier
MInolta Di 183
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Thanks.
Mar 25, 2009 | Minolta DiALTA Di183 Copier
MISFEED ERROR AFTER POWERING DI 2510 PHOTOCOPIER
look for small black levers, and see if they have a piece of paper on it, or if stuck
Jan 22, 2009 | Minolta DiALTA DI2510F All-In-One Laser...
Konica Minolta DiALTA Di183F Copier Logo
530 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
