You say 'Crank, no start', but you also say 'it will not turn over'. They are the same thing, if it cranks, it is turning over, but not 'firing' or 'starting'.
After you disconnected the battery, did you reset the Security System and Engine Immobilizer? You know it has one, that flashing light on the dash?
If that doesn't fix it, an auto electrician with a $5,000 professional grade Autel scan tool will be able to diagnose the entire car in 30 minutes. A $130 scan tool is garbage.
24 mins ago - The battery in my lexus gx 470 needed to be replaced it was hooked up wrog and the 140 amp fuse was blown how do i replace the 140 amp ...
There is no battery in the Honeywell 6160 keypad. It is powered by the transformer in the control panel. If it is showing BAT on the keypad, check the main system battery in the control panel.
The low battery light will stop flashing when the new battery you just installed become fully charged.
It will take some time for the new battery to become fully charged.
How old is the unit? Make sure you are wetting the electrodes on the strap and it is snug around your body and in contact with skin just below your chest if female under your sports bra. If that doesn't work the battery in your strap may not be good.
