Question about Whirlpool Freezers
A LOT OF ICE CONCENTRANTION INSIDE THE CABIN - Whirlpool Freezers
    Sergeant:
    Novelist:
  • 277 Answers
Http://www.applianceaid.com/frig.html
check out this link. also this link for more help http://www.applianceaid.com/ice.html
Posted on Mar 02, 2009
Leaking a lot from water filter, which is inside and on roof of refrig.
Has the filter ever been frozen? that can cause it to crack. If not, it is probably going to be the filter head that has failed seals... Whirlpool Refrigerator Water Filter Housing WPW10238156
Mar 17, 2016 | Whirlpool WRF989SDAM 29 cu. ft. French...
How do I clean this machine?
you don't give a lot of information.
Outside with detergent and warm water. Stains with something like Comet.
Inside, if you have ice build up, switch the freezer off. Fill a bucket with hot water, and place inside for an hour. The ice build up will come off with a plastic scraper. DON'T use a knife! Wash down with soap and water, switch back on and leave an hour to get to temperature.
Aug 12, 2015 | Freezers
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 17, 2013 | Freezers
Fridgidaire freezer warming up
Sep 09, 2013 | Freezers
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Jun 04, 2017 | Samsung RF217ACPN - 20 cu. ft. French Door...
Sub Zero ice maker (Model 235) not making ice, warm inside
try first. condenser ciol clean. is the water cold? is cutter grid in god shape? the brackett under the evaporator is attached?
Apr 02, 2010 | Freezers
Freezer had been working well for a month or more, then following it being moved possibly as a workman was checking my appliances for leaks, the top of the inside grew thick ice. I defrosted it but within...
Normally that amount of ice denotes a leak in the system, or possibly the thermostat not switching off. If the door does not seal correctly, you will also generate a lot of ice. Something tells me we are looking at a leak.
Oct 23, 2009 | Candy Freezers
Sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Jul 01, 2009 | Freezers
Freezer icing and causing water at the same time
fault is probably the door seal. to check seal, use a slip of paper trapped between door seal and cabinet
Sep 14, 2008 | Freezers
Freezers Logo
42 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Justin Duby
Justin Duby
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
