Question about OKI C5800Ldn Led Printer
Oki C5800 prints magenta streaks
Hello All,
With 69% magenta drum left, Okidata technician says I need a new drum which according to Okidata is out of warranty. Total pages printed is almost 6000. New toner cartridriges are installed. Machine is less than a yeay old.
Thanks in advance for replying.
Regards,
Mr. H
Hi all,
My oki C5800 keeps missing parts of a print. i print my own leaflets on photo paper and all of a sudden the image and writing in parts have lifted and not stuck down. my guess was the fuser so i took it out and had a look and i can see toner on the roller. is there any easy way of cleaning this as the fuser is only on 95%.
Thanks
Dave
Soulvisitor
  • 1113 Answers
SOURCE: OKI 5600 - Can you do a 'clean'?
Clean Cyan led head (on lid)
Replace Cyan drum with new
Posted on Dec 20, 2007
  • 32 Answers
SOURCE: Oki C9500 Printing Problem
Check the LED Head and LED Connection. The LED heads are interchangeable, BLK, Cyan, Magenta, Yellow.
Posted on Feb 15, 2008
SOURCE: STREAKS WHEN PRINTING
Thank you. I will go check into this and see if this helps.
Posted on Mar 16, 2008
rylee_smith
  • 8619 Answers
SOURCE: Oki C5800 prints magenta streaks
Streaks can be caused by a number of things
The fuser
The ETB
The toner cartridge
The firmware
The printer needs a cleaning.
The slot in the printer.
Incorrect Media.
Try cleaning the printer, use a lint-free cloth for the ETB, DO NOT touch the belt with your fingers, the oil from fingers will often make things worse.
Always use a lint-free cloth, if you ever encounter dirt inside the printer, dampen the cloth.
Calibrate the printer.
From the printer's control panel menu
Configure Device-> Print Quality-> Calibrate now.
(Press the Checkmark key to advance through menus)
Posted on Jan 14, 2009
SOURCE: OKI B6300 Drum problem
Hello, com_jedi. I would suggest you contact the OKI Customer Support line in order to address this issue. The phone number is 1-800-654-3282 (800-OKIDATA). For your model unit you would hit options 1 then 4 to get to mono support.
It is possible that you purchased a defective consumable and OKI warranties them for 90 after the date of purchase. If this is a new drum/toner it may need to be replaced to determine if it was a bad chip in the cartridge or if there is some other issue with the unit that is causing the error.
It is also possible there is a misalignment with the sensor that is located under the drum unit. A support tech can walk you through the troublehshooting as it would be a bit difficult to do here.
I hope this helps!
Posted on Feb 12, 2009
Oki c5800 belt life reset
It may require a complete service kit, you should check with Okidata to see if there is a kit available or what steps you should take to reset the life counter.
Jan 29, 2013 | Oki Electric Industry Okidata C5500, C5800...
Okidata c9650 printer. technician told me to replace transfer belt in my unit because i was having an issue with the color print quality. It had a light streak running through it and the top of the page...
That message is indicating that you need to replace the black drum which also may have been what was causing your origanal issue. Whenever you have a print quility issue print four seperate documents each document using one of the four colors (black, yellow, magenta, cyan)used by the printer. If the problem only shows up in one color then that is where the problem is coming from.
Jan 21, 2011 | OKI C9650HDN Led Printer
Okidata C5200N printer: streaky copies on magenta
If the streaks are only from the magenta then your magenta drum is bad. If you recently replaced it, it may still be under warranty.
Jan 19, 2010 | OKI C5200n Laser Printer
I have a Oki C9500 laser, the magenta print is streaky
I have the same problem with my OKI c3100, please help
Jan 13, 2010 | OKI C9500dxn Led Printer
Drum not spinning properly
open the top cover, there are 4 black leds above the drums attached to the upper cover, these can get toner on them and cause streaks as they are what write to the drum. wipe them with a dry cloth and see if that helps
Jul 25, 2009 | Office Equipment & Supplies
Oki 5150 color are not print right
You need to replace the magenta drum. Just because there is life left; it's possible it is scratched. Also, take a cotton ball dip in alcohol and wipe the LED's off when the cover is open; those black things that are hanging down from the cover. Also, make sure your drums are installed in the proper spots (magenta in magenta slot). If the toner "rubs off" after it prints... then the fuser is defective.
Jun 25, 2009 | OKI C5150n Led Printer
LED Head Missing, Color:Magenta
Take out the magenta cartridge to the right upper indside wall of the printer you should be able to see a small rectangular window, give it a blow of wipe with a cloth, do the same to the corresponding part of the m toner, put the drum and toner back, shut the lid and everything should be ok. If not contact oki for a replacement drum/cart.
Mar 23, 2009 | Office Equipment & Supplies
The fuser
The ETB
The toner cartridge
The firmware
Incorrect Media.
Apr 28, 2008 | Office Equipment & Supplies
OKI C5800Ldn Led Printer Logo
175 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
