Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Toyo73 displays ee-2
Toyo lazer73 displays ee-2
  • 22 Answers
It's running out of gas for many reasons. If it's been more than 2 years since you tuned it. 1) Just out of gas 2) Contaminated fuel 3) Too much head pressure at the unit 4) Plugged/dirty pump
Posted on Dec 12, 2009
    Novelist:
  • 126 Answers
Tootone,
Try this lick to REE. They are Toyotomi supplier on the west coast.
http://www.rural-energy.com/publications/catalog/document/334
Tom Hawkins
Bethel, Alaska
hawkins111@gci.net
Posted on Mar 07, 2009
Te 522 error EE
EE stands for Energy Efficient. The problem could be:
1) a bad thermostat 2) inadequate ventilation (blockage) 3) a bad controller board if the unit does not come on following this display.
The manufacturer pretty much decides what these specific codes mean. You might have to contact them.
Apr 07, 2015 | Heating & Cooling
My Toyo Laser 30 has an error code EE 5 and I can't find any info on that particular code. Help?
Call manufacturer or Installer - Direct Vent Furnaces are not a DIY service. Carbon Monoxide is deadly and can easily be emitted if there is something wrong with the heater. Get professional help before anything further is done, as it needs a full inspection for your safety.
Apr 14, 2014 | Rinnai Toyostove Direct Vent Heater: Laser...
How do I do exponents on this calculator?
Two keys can be used to enter negative exponents on the TI-30Xa scientific calculator; the [y^x] key or the [EE] key. The [y^x] key is used for all exponents while the [EE] key is used for scientific notation only.
The examples below will demonstrate how to use both keys:
1) Entering 7^-2.
• Press [7] [y^x] [2] [+/-] [=].
• The calculator will display: 0.20408163.
2) 1*10^-3.
• Press [1] [EE] [3] [+/-] [=].
• The calculator will display: 0.001
Sep 18, 2011 | Texas Instruments TI-30XA Calculator
I let my tank empty before refueling and now my toyo laser 56 has a ee 2 error on it how can i fix this?
You should check the filter at your oil barrel if you have one there and loosen the small vent screw to bleed the filter and line. You can also check the strainer in the fuel sump but remember to turn off the fuel at the barrel before removing the strainer from the sump. Also press the float reset button on the full sump. You can loosen but not remove the fuel line on the back of the heater if needed to get the fuel flowing. Be sure to place something under it to catch the kerosene and have some rags handy.
Jan 03, 2011 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove laser 73 displays ee 10. Toyo is brand new, no obstructions in flue, fuel tank is a good height, only pressed red button once for a second, blower fan works.
ONCCON,
EE10 is not good. This means you had a flame in the pot when there should not have been one. The red button is to be used very carefully. One time for one second. I think you have pushed the button too much and got a fair amount of fuel into the burner. Without pushing the red button try the stove again. If you burn out the fuel in the burner the stove will operate normally. If the code continues I would look at the hook up for the air and exhaust to be sure they are correct. If they are backward it can cause an EE10.
Keep us posted,
Tom
Jun 01, 2010 | Rinnai Toyostove Direct Vent Heater:...
When i enter 10 exp (-)2 equals, the calculator displays the result as 0.1 when it should be 0.01? why would this be happening?
The [EE] or [Exp] shortcut is the source of much grief to the students.
When you press the [Exp] 0 you are in fact entering 1.00 so
[EE] (-)1 [=] gives 0.1
[EE] (-)2 [=] gives 0.01
Thus
10[EE](-)2 is 10[x][EE](-)2 or 10[x]0.01 = 0.1
The new generation of calculators does not have the [Exp] or [EE] key. It is replaced by a key with a more explicit label [times 10 to the X]
Hope it helps.
Sep 23, 2009 | Casio FX-300MS Calculator
Inputing Scientific Numbers
If you mean using the "EE" key it's straightforward.
To enter scientific numbers, enter the number, then press EE, then the exponent value. The TI-30XA will stay in scientific display until you "clear" or turn it off. It will also switch to scientific notation if you multiply big numbers that exceed the display.
E.g. Input 3, EE, 10, X, 3, EE, 10, =, gives you the answer 9 times 10 to the power 20. Press the "square root" key and you will get back 3 times 10 to the power 10.
You can mix entries too, e.g. 3, EE, 10, X, 2, =, gives you 6 times 10 the power 10....
Nov 29, 2008 | Texas Instruments TI-30XA Calculator
Laser 56 small explostion
I don't think it is dead. I would have a service tech come out and look at it. The igniter sounds like it's not working properly.What kind of fuel are you useing
Apr 06, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Ee 12 code
Hi alaskasteve,
My business is Laser Heating Service in the North Pole/Fairbanks area of Alaska. EE12 is the error code for overheating. Most likely you have a Laser 30 giving you this error code. The most common reason for the EE12 error code is that the Toyo is not getting enough air circulation across the heat exchanger and causing it to overheat. Look at the back of your Toyo where the black frame around the circulating fan and flue pipe is. You will see a screen that slides in a slot at the back of the Toyo. Slide the screen out and clean it. If you have a smoker or the Toyo is in a kitchen area where it collects nicotine or grease then you may need to clean it with hot water, detergent, or 409 Cleaner to get the sticky residue off that the dust fuzz collects on and clog your screen. EE12 can be caused by a couple other issues, but they are more rare. Try this first and let me know if it works! toyotechnician
Jan 15, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove Laser 30 has error code EE 22
EE-22 means that the unit has tried three times to ignite. after this it goes into a "lockout" condition. remove the power and the computer will reset itself. it will then try to re-ignite. check for a fuel blockage, dirty filter etc. if there's water in your kerosene it will not fire! kerosene floats on top of water. bleed your system until you get kero and no water. use a gas additive to remove water. dry-gas will work. just empty the bottle's contents into your tank. on your computer type in toyostove error codes. this will take you to toyo's site and explains the error codes.
Oct 20, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
266 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
