Question about Microwave Ovens
Sharp Carousel R-1481 Turntable
The turntable in my microwave oven stopped turning. It makes this noise like it's trying to turn. Yesterday, in the microwave, for 1 minute, I heated an egg with shell and it exploded causing the door to pop open and the glass turntable slid off its axle. Did I damage the turntable?
Today, I turned off the turntable and was able to heat my food the regular way.
  • Microwave Ovens Master
  • 9,086 Answers
It may very well have have damaged the turntable motor.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
On many Sharp models, you have to cut the motor cover off with snips, then use a screw when reassembling it.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Be sure if you cook an egg that you puncture the shell first so it can breathe.
Posted on Mar 02, 2009
  • Marckcj Jan 09, 2011
    I read this post for the answer on how to remove
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
Sharp r-1850a turntable problems
turntable motor p/n 46-841666-3, available from searspartsdirect.com, use correct model #!!
Feb 09, 2013 | Sharp R-1850A Convection/Microwave Oven
Sharp R-405H microwave turntable doesn't rotate and makes strange noise
Replace the turntable motor, it is defective and will only get worse.
Mar 17, 2012 | Sharp R-405H 1100 Watts Microwave Oven
My over the stove Sharp Carousel Model # R-1505F turn table stopped turning. What part do I need to replace. Also, I broke the glass turn table plate. What size is that and where can I order another...
Sears Parts Direct has the parts diagrams and many parts for the R-1505 microwave. The glass plate is part 4-3 ($33.99) on this page: http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R1505/0958/0123370/50019999/00001?blt=06&prst=&shdMod= .
Without more tests, I can't be completely positive but the turntable motor is the likely problem. That is part 1-4 on the list above. However, it could be a wiring problem with the wiring to the turntable motor.
Partstore.com has many of the parts as well: http://www.partstore.com/Model/Sharp/Sharp/R1505.aspx .
I hope this helps.
Jul 29, 2011 | Sharp R-1505 Microwave Oven
My Sharp Microwave R-1460A make load noises when turntable is on. Noises stop when turntable is turned off.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 11, 2011 | Sharp R-1460 Microwave Oven
The carousel in our Sharp Microwave/Convection Oven suddenly stopped turning. Nothing seems to be blocking it--it whirls around when I push it. Any ideas?
Got someone to come look at it, and the motor for the turntable has burned out! We're ordering the part!
Thank you!
A.
Oct 07, 2009 | Sharp R930CS Microwave Oven
Squeaky carousel
It can be oiled with something akin to Pam (cooking oil spray). You don't want petroleum products in your oven -- it'd take forever to get the fumes out.
I'd try first just spraying some under the turntable as far back toward the center as you can get it -- run oven -- spray some more, etc., etc.
Charlie
Aug 15, 2009 | Sharp R-1480 Microwave Oven
CAROUSEL STOPPED TURNING
Turntable motor req,Or drive shaft on top of this.
Oct 07, 2008 | Sharp R-1480 Microwave Oven
Microwave Ovens Logo
584 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
