Question about Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G
530s series wire set up no manual
Audio setup for the 530s series speakers not on monitor need assistance for wiresetup for brandnew out of the box hopefully pictures.
  • 59 Answers
Here is a link to the online manual for your computer read down the manual and it will tell you how to wire up the speakers.
http://support.dell.com/support/edocs/systems/insp530s/en/OM/HTML/setting.htm#wp1135843
Hope this helps.
Posted on Mar 02, 2009
Compaq JBL Platinum Series Speakers not working on Windows Vista
change the audio and sound device setting in the control panel. try to change the speaker setup
Oct 05, 2009 | HP JBL Platinum Computer Speakers
Tv problem
Since the NEC is not a TV but a monitor, it does not have a tuner nor speakers that it why it has no RF input. So if you want to watch TV on it you need a cable box with an HDMI and an audio out, and a pair of amplifed speakers. You can use the cable box's universal remote to turn your monitor on and off.
To get TV video, get an HDMI-to-component video (red/blue/green) cable then to get audio connect the cable box's red/white RCA audio out with an inexpensive set/pair of amplified PC speakers. For this you need a 3.5mm-to-RCA adapter to hook these up properly.
Because the audio is coming from independently powered speakers, it will be nice to have a set that goes on standby when there is no audio signal from the cable box. This would eliminate the need for you to stand up and power off the speakers when you have shut down your TV (monitor) and cable box. Or even better, get one that has a remote so that you can raise or lower the volume or power off as needed.
Hope that helps.
Aug 28, 2009 | NEC 42 in. EDTV-Ready Plasma TV
How to set up 6.1 divinci home theatre system to 42inch HHD LCD T
davinci DA-6.1 home theatre tokk it out of box their is only speaker wires that connect on to another no power source or wires to tv I need help
Jun 27, 2009 | Audio Players & Recorders
Audio
Are there speakers on the monitor? If it has speakers then they need to be connected to the speaker output[s] on your soundcard. Usually with dell it is colorcoded green on the back of your computer. Hope this helps.
Dec 21, 2008 | Dell Inspiron 530s Desktop Computer...
Monitor going blank
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Sep 29, 2008 | Logitech QuickCam Pro 9000 Web Cam
Compaq wf 1907 monitor speakers--no sound
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
Monitoring own picture in SKYPE
Recheck settings as listed in info below.
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
NOTE: You audio and video should work. Enjoy.
Dec 04, 2007 | Logitech QuickCam Pro 5000 Webcam
Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G Logo
148 people viewed this question
Alun Cox
