Question about Dometic Rooftop RV Air Conditioner
Wont work 15000 dometic air conditioner compresser wont start fan runs fine
  • Anonymous Mar 28, 2014
    Fan wont run unless started by hand spinning
    Guru:
  • 462 Answers
Well the 1st thing is see if your compressor is hot, warm, cold to the touch after yourve tried to run it for 30 min to 1hr.
If its cold proceed to check the voltage at terminals R and C. Careful they might be hot electrically. If its cold my bet is your thermostat or Contactor if so equiped is not closing. A thermostat you can wire around putting the wires together for a test (remove power before this though) Usually if you have a contactor you may be able to see the points and push the center bar (plastic bar) in and see if the comprtessor starts.
SOme times some of the units have an extra set of contacts on the Swich that you turn it on to cool with and these have to close also. If you check across the terminals of the thermostat or contactor or switch with knowing which one is the line in and which one is going out to compresso or next control in circut it should read NO VOLTS or vary few <10 on a digital meter.If it ranges between line and 10 volts you have found the most likely suspect of the problem. wire. If this is confusing I could send you or fax you an explanation. control
If power is there to R & C and the motor is HOT or warm The problem could be a dirty outdoor coil or a bad run capacitor. Disconnect power and remove capicator. Let the Compressor motor cool off for at least 4 hours and maybe over night. Remove 3 wires on Compressor and check across all 3 to each other you should read the least resistance tween R-C the most tween R-S and a reading tween these 2 tween C-S. If these readings check out (They could range widely as to the mfg of the compressor motor but they are required to follow the description I stated). If you now have these treminals checked and thar are as stated reconnect wires. Assuming you have power to the compressor at R-C next have some one turn it on and see what you hear. A momentary hum or does it start running. A momentary hum could mean the compressor is stuck or the run capicator is faulty. Check the run capicator. The case will usually be Gray or Auluminum and may have 2 or 3 terminal sets with 2 to 8 wires. It is important to replace then to the exact terminals so make a diagram before or as you remove them. Examine the case for signs of oil leakage or swelling. the tops and bottoms are generally flat so if it isnt take it to a parts house and let them check it for you. If it still dosnt work ask the parts houst for a quick Start/ relay - capicator assembly to try. If this breakes it free then there you go if not and you ahve power to the terminals looks like compressor is gone.
Posted on Mar 02, 2009
  • 306 Answers
Can you locate the capacitor to the unit. It is a dual type sounds like you lost half of it. Write down the wires that go to it and get a new one. Now in the event it is good get back with me. ken
Why am I not getting power to ac capacitor?
A thermostat or a relay activated by the thermostat turns power on to the capacitor for the compressor.
May 03, 2015 | Dometic 459196 Duo-Therm Brisk Air...
I have a Dometic 15K roof Ac on my FW. After the AC reaches therm temp, the compressor and the fan turn off, but the fan starts right back up again and runs until you set the thermostat on off.
That is normal operation, only the compressor cycles, the fan stays running to keep air circulating for better temp control. Otherwise the rear of the space could get 5 degrees warmer than the front
Feb 23, 2015 | Dometic 459516 459516.XX1C0 Brisk Air...
15000 btu roof top does not cool but fan will run.
compressor capacitors, thermostat, relay module, bad compressor, lost charge of freon.
Apr 26, 2014 | Dometic 57915531 Air Conditioner
Starting amps 15000 btu ac
with a good start capacitor you will not have time to read starting amps. it should drop to running amps almost instantly.
Jan 08, 2014 | Dometic 57915531 Air Conditioner
My duro therm 15000 btu air conditioner runs fine until set temp is reached. The unit then starts to cycle on and off about every 2 minutes.
Service your indoor and out door. Due to over dusty, sometimes, this type of malfunction may happen. Thanks.
Oct 16, 2011 | Dometic Rooftop RV Air Conditioner
Dometic Duo Therm, 15000 BTU: Thermostat works, fan runs, but no cool air. Any ideas?
Check the compressor and the condenser fan to see if they are running;they will have to be checked from the roof. If one is running and not the other then check the capacitor for the one that's not. If both are off then check the contactor that controls them. You will also want to make sure they are getting power. If they have power and the capacitors are good, check the motor windings for the fan and compressor. Hope this helps. Let me know what you find.
Aug 04, 2010 | Dometic Rooftop RV Air Conditioner
Have a Duo Therm 59516.531 15000 BTU blower motor does not run checked cap 5mf ok tried direct power still nothing any thought. thanks
if you tried direct power and still nothing then your fan needs to be replaced . there should be a a/c supply store near you . get the model - serial number on the fan or the unit itself to get the right fan for your unit . hope that helped
Jul 01, 2010 | Dometic 57915531 Air Conditioner
A/C TRIPPED BREAKER
Try the FAN ONLY position and start it.
Could be a stuck fan motor or a bad capacitor..
Remove the cover. Have someone turn it on. Once they turn it on spin the fan by hand. If it starts and runs replace the capacitor.
Mar 26, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
245 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
