Question about Bulova Watch
Need instructions for sieko ska381 kinetic watch
Got a new sieko ska381 kinetic watch but the instructions in the box were for a different watch. canyou tell me where I can get a copy tor this watch?
    Master:
  • 497 Answers
Http://www.seikowatches.com/support/ib/index.html
try this page
THanks for using Fixya
Have a nice day!
Posted on Mar 05, 2009
No work quartz
This watch is kinetic, in that a moving rotor inside the watch powers a rechargeable battery that runs the quartz mechanism. You should not need to attempt to open the watch! It may be that the battery is flat (especially if it's not been worn for a while) - you can try swinging the watch back and forth to charge it (check online for charging instructions for Seiko or Pulsar kinetic watches). If that fails, take it to a reputable establishment for repair.
May 22, 2016 | Steinhausen Stahlhammer Dual Time...
My kenetic battery ( i think) operated watch ,N0, on the back plate-
First, does it say "Kinetic" on the face of the watch? If not, it is not a Seiko Kinetic. (You did not mention if it was a Kinetic or not.)
Second, the Serial number is not like any Seiko Kinetic I know, which is 2 4 digit numbers.
Third: The number you gave itself may indicate the type of button battery you need.
Good luck.
Mar 02, 2013 | Seiko Kinetic watch
On my sports 50 it stops if it is off of my wrist for 14 hours . Also I dont know how to change the day sign to english
This is obviously unsatisfactory and I can understand your problem. Even spring driven automatic watches will run for 2 - 3 days when not worn.
Your watch can either be charged by use (i.e. wearing it) or by winding the crown wheel, although there seem to be a variety on kinetic watches and it is not clear if all of them can be wound by hand (mine can't but it goes to sleep after two days and can stay in this mode for 3 months and re-starts when it is worn!)
For a fully description of the kinetic operation go to http://www.seikowatches.com/technology/kinetic/kinetic_dd.html and there you will will see a choice of kinetic watches.
You can also access the instruction manual list to check out how your watch is intended to operate. Some watches indicate days in two languages (as yours appears to do) and you can select the correct day by pulling the crown wheel to the middle position where you generally change the date by rotating it forward and the day by turning it backward. When turning it backward, you should see and alternative day and you should stop at this position. The watch will continue with the same language after this.
If this does not work, then you should be able to find out the day sign after reading the instructions.
If your watch is new and after reading all the literature you still cannot sort out how to make your watch run for a longer period, then contact the maker who should be able to help.
Jan 02, 2011 | Seiko Kinetic watch
I need instruction manual for a Seiko Yacht Timer Case No. 8M35-8009
mcdevito75 here, You should be able to contact Sieko online, try Sieko watch.com
Jul 07, 2010 | Seiko Watches
Instructions for seiko watch
Go to "sieko.com", click on "support" and click on "instruction booklets" in the menu on the left.
Apr 04, 2010 | Seiko Silver Chronograph Tachymeter 100M...
Breitling Colt Kinetic Watch - not working
I read the instructions for a similar type of watch and while the battery will keep the watch "alive" for some months when not in use, eventually the battery dies.
Since it is a kinetic watch the instructions I read said that you should gently shake the watch about 500 times to recharge the battery!
If you give it a good shake and then wear it for a few days, it should recharge itself, although it may have forgotten the time and may need re-setting.
Mar 01, 2010 | Breitling Colt Oceane 504 Watch
My kinetic purchased in 1995, started to not fully charge and show a full charge. It runs only a short time before stopping, this happened suddenly after years of perfect operation. The watch is in good...
It is a little old but should give many more years of service. I suggest that you have it cleaned, this should make all the difference.
Since these watches contain a battery it might also be a good idea to have a new one fitted.
Jan 17, 2010 | Seiko Kinetic watch
My sieko watch face moves around inside ?
It sounds like a problem that can be solved by removing the mechanism from the case.
If the watch is within the warranty period your local dealer for that make should do it for nothing.
If it outside the warranty period, is probably best to let your local jeweler re-fix it.
Jan 12, 2010 | Seiko Watches
Can I use an ordinary button cell in a seiko kinetic
I have been trained by a Master watch maker and I have worked on many Seiko Kinetic watches. Yes the original watches came with a capacitor that is charged by your arm movement. But unfortunately, they seem to only last a few years. All replacements are now done with a Lithium Ion battery that is much better and lasts longer than the original capacitor. This is the correct solution and don't try to use a battery type that is used in other quartz watches.
Oct 01, 2009 | Seiko Kinetic watch
Bulova Watch Logo
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
