Question about HP Computers & Internet
Immediately upon boot, vertical lines appear on screen. After several minutes the screen turns pick and the windows cursor appears. there is no further change in the display. Mouse appears to work. Not keyboard. Any thoughts?
    President:
  • 948 Answers
My first check would be video drivers if this is a newly built computer. If it is a computer that has been running a while and the problem suddenly appeared I would reseat the RAM and attempt to boot into safe mode, suspecting a virus infection.
Posted on Mar 01, 2009
Samsung Plasma HPT5054x/XAA has several light gray yet transparent horizontal and vertical lines. Is it the Board or Panel?
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Nov 01, 2016 | Samsung Televison & Video
Black screen blinking line in upper left corner
you just need to re-install the Operating System from recovery cd
Dec 19, 2012 | Dell Dimension 8250 PC Desktop
Vetical lines appear & a horrible noise, have 2 reboot numerous times per day gateway P-6822 series
Vertical lines are usually caused by an lcd hardware problem.
Can you boot the computer to an external monitor?
Do the lines appear immediately after starting the comptuer?
Nov 29, 2009 | Computers & Internet
Startup repair won't run
"Unmountable boot volume" this problem is your hard disk partition which is failure to recognize & identify the operating system running on the hard disk. Reformat your hard disk and put another operating system to run again your computer.
Jul 27, 2009 | Computers & Internet
Computer only displays vertical lines and pink background.
Most likely an issue with the Video Card or Video driver.
* Boot to safe mode by tapping F8 while starting up the computer. Selected safe mode with the keyboard and hit enter. Login to your user account. You should see the words “Safe Mode” on all four corners,
* Open device manager – Right click “My Computer” – Select “Manage” – Selected device manager from the left. Under display driver, you should see your vide card listed. Right click on it and select “Disable”.
Now restart your computer and if this resolves the issue, then the vide card may be at fault. You could also try updating the video driver.
Do let me know if you get this far.
Mar 01, 2009 | Dell Dimension 4600 PC Desktop
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Computers & Internet Logo
65 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
