Question about Equipex PZ-330 Electric Single Oven
Electric fan oven overheating
I have a Baumatic electric oven to which I have just replaced the broken element as it was not heating up anymore. Unfortunately, after switching the oven back on, I notice that the element keeps overheating, becoming incandescent and the RED thermostat light stays on and fails to regulate it. Before switching the oven off I checked if the thermostat light would go off by lowering from 250 to 75, but the red light stayed on. Can someone help me determine if the original spark that damaged the element I changed in the first place, as maybe also damadge the thermostat.. what I should do now? I don't feel safe using the over as it is now. any suggestions.. many thanks
  • Equipex Master
  • 3,463 Answers
It sounds like the thermostat is faulty, make sure the sensor is not detached inside the oven compartment, as this will affect the thermostatI if it is. If o/k, then the only option is to replace the thermostat. If it is fan assisted, then make sure the fan is working o/k as well.
Please leave a rating for my comments.
Thganks.
Posted on Mar 02, 2009
Why has baumatic B501SS oven covered in light gray coating inside when heated, now not working
It sound like the heating element burned out. Check the element and see if there is a burned spot or blister somewhere along the element. If so the element will need replacing.
May 03, 2014 | Baumatic B180 Electric Single Oven
My Baumatic B180W-B oven does not heat up. The
If the oven is electrically heated, then more than likely, the oven element has failed.
This is located behind a removeable cover at the rear of the oven.
Feb 21, 2010 | Baumatic B187 Electric Single Oven
Baumatic oven not heating up. Grill and fan fine.
if it is the b180, the answer (having just fixed this) is really simple.
The coily bit is the oven element - it will have gone. A new one from eBay cost me about 6 quid.
[WHEN IT ARRIVES !]
Turn the power off.
Inside the oven use a philips screwdriver to remove the 4 screws (KEEP THEM !)
You will see a coily thing and a fan.
You unscrew 3 more screws (2 on the left and 1 on the right).
(KEEP THESE TOO!)
now ... bit tricky, have the new one inside the oven and take each wire off one at a time and put it on the new element.
Screw it back on but DONT put the last panel back in.
Turn the oven on maximum for about 2 minutes and see it glow red.
Turn the oven off. Make a cup of tea and have a couple of biscuits while admiring how good you are and waiting for the element to cool down!!!
Put the final panel back in place. Whole thing (including a cup of tea) takes about half an hour.
Jan 27, 2010 | Baumatic B180 Electric Single Oven
My Baumatic oven now displays F4E0 after a power surge, the fan still works but there is no heat.
more than likely the heating element blow but check to see if theres a fuse in line with that element
Jan 23, 2010 | Baumatic B187 Electric Single Oven
Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Baumatic B180 Electric Single Oven
Baumatic B501SS Built In Stainless steel electric single oven
If the fan is working in the main oven and there is no heat, then it will be a faulty element.
Remove the cover at rear of oven
and you will see the round element. remove it and replace with new one.
Plz rate my solution .
Thanks.
Jan 17, 2009 | Baumatic B180 Electric Single Oven
Fan oven not heating up
If fan is working then the element has probably gone
Nov 29, 2008 | Baumatic B904SS Stainless Steel Electric...
Baumatic 1870ss steel electric oven
sounds like your element is not wired in properly or its faulty get someone to look at it
Aug 28, 2007 | Baumatic B187 Stainless Steel Electric...
No heat in oven
the element may be open circuit, test it by a continuity test. the actual element is inside the metal outer surrounded by a ceramic compound -you will not be able to see any breaks hence the electrical test.
Jun 05, 2007 | Baumatic B180SS And B60SS (Bundle)...
Baumatic bt180 oven
assume a fan oven.does fan turn and oven light come on? if so problem is the circular element. if no fan and no oven light, then clock probably needs setting - this will be in instruction book. clocks sometimes go wrong but not often. if clock is faulty, a cheap repair is to bypass the clock so auto function no longer works
Apr 09, 2007 | Baumatic B180 Electric Single Oven
Equipex PZ-330 Electric Single Oven Logo
185 people viewed this question
Top Equipex Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Equipex Oven Expert? Answer questions, earn points and help others
