Question about Bunn Pour-Omatic Coffeemaker, 10 Cup White
Keeps tripping gfi upon turning switch on. ruled out burner plate after disconnecting wire. element looks to be in one peace and no wires are exposed for dead short. anyone ever encounter same problem?
  • sph1469 Mar 03, 2009
    Thanks I am going to order part today and will keep you posted on the outcome.
    Novelist:
  • 125 Answers
Hello. I have seen the tank heater not blown, however, it has a high resistance to ground through the water, replace it, and all is fine. You would need a good multimeter to test this problem, there must be a small crack in the sheath of the element, and is able to bleed a little leakage through the water, not enough for a normal outlet, but a gfi, no good.
Hope this helps, and thank you.
Posted on Mar 01, 2009
  • Jim Apr 13, 2009
    How did you make out on this? is it better now?
Hello, My x5 keeps popping my kitchen GFI plug in the kitchen, i plug it into a non GFI and the top light (heating element) flickers when turned off. When turned on it appears to be working ok?
Stop! Do Not use this machine until it can be serviced by your vendor or the MFR!
** There is probably an open or ruptured heating element in your brewer. The heating wire is embedded in a sand filled copper tube which is immersed in water. Sometimes when the copper tube cracks or leaks allowing water to seep into the heated wire. This will steam the water and rupture the tube thus exposing the element directly to the water in the tank. Most units will short out and trip out any breakers by overloading the line. Some will still heat the water but this is a dangerous situation as the 'short' in the water will still heat up the water to a high boil and may rupture to whole brewer. If your power cord does not have a good 'ground' wire then there is a strong chance your operators will get a shock while touching the machine and another 'grounded' machine (like the grinder)
** Be safe and get it properly serviced.
Aloha, ukeboy57
Dec 05, 2017 | FrancisFrancis! X5 Espresso Machine
I have a steamist lt90 that we recently installed. It stays on for about 5 minutes then trips the breaker. It was installed using #10 wire and a 30 am breaker. Any ideas?
!!!!!First look on data plate see what is the rated amperes and kW . Make sure what code is for steam generators.
Some steam generators do not recommend GFI circuits to avoid nuisance tripping.
If you can us GFI in circuit breaker you may need two hots a ground and a neutral.
As a rule
30 amps = #10 wire
40amps = #8 wire and
50amps = # 6.
Generators normally are 240vts the two hot wires connect to # 1 and #2 wires coming from unit.
Aug 26, 2015 | Dryers
I have a apw wyott eletric hot plate model chp-1a. Lately, it keeps on tripping the circuit. Can any one tell what's wrong? thanks. tt
If the breaker trips immediately when you plug it in, then you have a short in the power cord. If it trips when you turn it on then look for a short at the switch or the burner element. If it stays on a while and heats up then trips, it could be a fault inside the element or possible wiring connectors that are not good and tight. Look for discoloration in the wires and connectors.
Aug 04, 2013 | APW Wyott CHP-1A Champion Single Open...
Is a house plug with a cfic braker light suppose to be red or green
Most are green when functioning properly. Many have no lights at all. Try depressing the reset and see if the outlet works again. If not there are other things to look for. Often times one GFI outlet feeds multiple more outlets from the "load" connection on the back side of the GFI. If there is something wet, overloading the rating, or something with a fault in any of the outlets multipled off the single GFI it will trip. Disconnect all devices then attempt to reset. If that doesn't work and you possess some electrical skills pull the GFI outlet and disconnect the wires going to the "load" connection (While power is off) Re-energize and attempt to reset the GFI Outlet. If it resets your problem is beyond that outlet in the circuit of what you disconnect. You may not have found all the affected outlets. FYI if you have a 15amp GFI the rule of thumb is you can put more devices on outlets working off or through the GFI that add up to more than 1500 watts. If it is a 20amp GFI a quick rule of thumb is no load over 2000 watts. Space heaters, blow dryers, and hair curlers are often 1800 watts each. One alone and can trip a 15 amp GFI.
Dec 28, 2012 | Zyxel PLA-401 v3 - Bridge - Ethernet, Fast...
Frigidaire GLRS264ZA refrigerator keeps blowing GFI circuit
The fan and defrost heater are run off the same relay on the board. When on defrost, the fan stops. when the fan starts, the defrost heater is switched off, Sounds like the neutral to the board may be shorting. If you have the ability, try powering the evaporator fan from the compressor relay, disconnecting from the board entirely. To see if this will work, just take a temporary wire to the fan when disconnected and see if it trips while running.
Aug 07, 2012 | Refrigerators
Colman Spa trips GFI what is most common problem? GFI test good. Pump disconnected still trips, is heater most likely? Can you replace only heater? thanks
this should be simple ...
1.shut off the power
2.disconnect wires to heating element
3. turn power back on and see if it works if so replace heating element 45-95 dollars
if it still trips unplug all the cables from the pumps blower ozonators and see if it runs now,,,, if so plug each cable back (one at a time) until it trips again.if it trips that the problem pump etc.
99 percent of the the time its not the gfi its a device that is wet or shorted out ..Try everything else before replacing the gfi
Dec 31, 2010 | Balboa Instruments BALBOA 30kW HEATER ASSY...
As soon as I turn on the boiler it pops my GFI instantly. Would this be the element or wiring or what?
Hi
Sorry to say but its your heating element. When they go bad it exposes the element to the water and creates a direct short. This short is what trips your GFCI. It needs to be replaced.
Oct 21, 2010 | Rancilio Silvia Espresso Machine
My left two cook top burners will not turn on.
check fuses and pull out burner elements see if they are damaged if fuse blows when turned on make sure wiring to elements is not exposed I would also check the switches for elements, turn on one at a time
Dec 18, 2009 | Kitchen Ranges
When i plug it in it trips my gfi and it is not on
This can be caused by one of two things. (1) The GFI plug has a problem: it could be broken behind the face plate, or some of the wires in the box are so close that when you push a plug into the outlet, they touch and trip the GFI. (2) The other source is due to a defect in the appliance between the cord and the power switch. That is why the GFI faults even before it the coffee maker is turned on.
Have the outlet checked thoroughly and make any needed adjustments / repair /replacement and reconnect the coffee maker again. If it trips, the coffee maker will need to be serviced. DO NOT use the coffee maker in another non-GFI outlet until it has been checked out. The chances of electrical shock or burns is significant until the problem is found and corrected.
Oct 02, 2009 | Bunn Coffee Makers & Espresso Machines
Refrigerator trips GFI outlet
unlikely to be the defrost timer. more likely to be the defrost element. try disconnecting the element and see if it trips then. could be of course a wiring fault - frayed wires etc
Jun 18, 2007 | Viking VCSB423 Side by Side Refrigerator
Bunn Pour-Omatic Coffeemaker, 10 Cup White Logo
129 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
